My 325-375HP TBI 327 build
1 Post
Car: 1991 firebird
Engine: TBI 305 (built)
Axle/Gears: 4.10
Hey there ppl .. I'm finally about to have enough $ to build the engine I want so here is the thread .. I should start ordering parts in about a month .. The goal is a 325-375 HP small block 327... I'm wanting it to be capable of 6000 rpm minimum .. I know anything over 6k is not easy with TBI ... I already have EBL Flash a TPI fuel pump and CFM TECH's 620CFM TB .. If 6k ain't doable with what I got 5500 will have to do I guess .. I am dead set on a 327 so I'm not looking for anyone trying to change my mind on that .. But if anyone has any comments or suggestions they would be greatly apretiated !! Here's a list of a few parts I have in mind..
CNC Motorsports 327 w/3.250 crank 6.25 rods 9.5-10:1 compression ratio ( eagle (lightweight crank) & rods gapless top ring (all ARP bolts)
AFR 175cc heads (assembled)
Hydraulic roller cam & full roller rockers ¡¡ Suggestions please !! I like crower
Single plane carb intake ( suggestions ?)
High volume water pump ( brand suggestion?)
New aluminum radiator ( brand ? Decent price ? )
Chromoly pushrods (crower)
Good timing chain set ( suggestions ?)
Any other suggestions would be greatly apretiated .. I'm trying
To get as much info as possible to do this right ! Thanks !
Ok now to tell y'all what I already have ..
•620CFM TB, EBL Flash ,TPI Pump, TT-2 WB
•Shorty headers 2.5"-3" y-pipe and full 3" exhaust W/3" cutout in front of rearend Into flowmaster muffler
•auburn 4:10 gears & Posi w/disc brake rear
•ws6 swaybars front & back w/ poly bushings & links
•UMI torque arm & LCA's w/ poly bushings
•torque arm relocation bracket
• drilled & slotted front rotors
•ram air 2 hood
Oh yea I also need an external FPR (suggestions please )
Let me know what y'all think !
•ram air 2 hood
1 Post
Car: 1991 firebird
Axle/Gears: 4.10
Re: My 325-375HP TBI 327 build
Oh yeah another thing I was wondering .. Is there an msd billet distributor or equivalent that is TBI compatible ?
Most of those parts will be up to your preference. Most critical would be the cam selection to match those heads, bottom end, and manifold. Like you said getting over 6k RPMs out of a TBI is almost unheard of, but your setup should make the power you want under that. Sounds like you have the right idea though.
For what its worth, I have a vortec 350 TBI, 10:1 flat tops, mild comp cam, GMPP TBI intake, stock TBI bored and am making around 330 HP running 13.6's all day in the 1/4
1 Post
Car: 1991 firebird
Axle/Gears: 4.10
Thanks man .. Like I said 6000 rpm shift point would make me extremely happy but 5500 would work for me .. What cam would u suggest .. And I'm actually thinking about downgrading on my head choice for a similar cheaper set .. I'm guessing the 175-180cc intake runners will be a good choice for a TBI 327 ? And anyone have any cam advice for this setup ? I'm wanting to keep it hydraulic roller . Thanks for any info !
I'd like to run 13.0000s .. W/ T5 & 4.10's
1 Post
Car: 1991 firebird
Axle/Gears: 4.10
I'm thinking about using these heads http://m.summitracing.com/parts/sum-162108
And if my cam i choose is too close to max lift I'm a
Use the titanium offset retainers .. Hopefully the springs are good enough for a hydraulic roller cam
1 Post
Car: 1991 firebird
Axle/Gears: 4.10
Cool thanks Ronny ! What Sony think of the parts I have listed so far ? And could any of u recommend a cam ? Hrdraulic roller preferably .. I wanna shift around 55-5800 ..
I'd like to shift at 6k but I don't think the TBi is gonna wanna go that high :-/
XR 276 HR comp cams 1800-5800 rpms 1987-1998 block 224/230 .05 112 LSA lift is .503/.510
you dont have a roller block do you? Then skip above.
instead 268 XFI HR13 retro fit roller uses 1.6 rockers
At 6,000 rpms you have 4.25 msec to fire one injector considering 85% max allowable for duty cycle. So you need a larger injector and high fuel pressure to deliver adequate fuel within that time constraint.
I too shift at 6000 rpms however I have 75 lbs injectors at 26 lbs fuel pressure. My DC is about 88% last I looked.
1 Post
Car: 1991 firebird
Axle/Gears: 4.10
Sweetness .. Could u recommend a cam and intake ? Also what do y'all think bout them summit heads ? What injectors should I use ? Also the short block ill e using is a straight up 327 ready to go with all forged internals and ready for HR cam .. I've looked into cams but dam* they r proud a them .. I've seen some lifter & cam kist for 400$- 700$ I'd like to stay on the cheaper side of that window lol ... Also thought about the summit reman vortex heads cause they are a little cheaper ..
Car: check
Engine: check
Transmission: check
The '113 heads have the exhaust crossover blocked, so easy to run coolant instead.
RBob.
Car: 1983 G20 Chevy
Transmission: 4L60
1 Post
Car: 1991 firebird
Axle/Gears: 4.10
I don't build enough engines to recommend many of the pieces. The current intake manifold is an Edelbrock Performer RPM with the center divider cut down. Also have coolant running under the plenum via the exhaust crossover.
RBob.
RBob.
Car: check
Engine: check
Transmission: check
It provides better drive-ability. Even on hot days a short WOT will chill the manifold by a great amount. It is helpful to have a consistent source of heat right under the plenum.
RBob.
RBob.
1 Post
Car: 1991 firebird
Axle/Gears: 4.10
Ok thanks .. I guess I will try to use the coolant method , I don't line the idea of hot a** exhaust under my manifold ... So how exactly do u tap the coolant into the manifold ?
There is an exaust assageway dead center head to head that can be tapped into on top of manifold. you should see a bump there on each side. runs right under plenum.
http://www.holley.com/data/products/...arge300-49.jpg
RBob once posted a photo of his set up in a thread I started a couple years back.
Car: check
Engine: check
Transmission: check
Pictures at post #17 in this thread:
https://www.thirdgen.org/forums/tbi/...gle-plane.html
The AFR heads usually have a drilled hole for exhaust crossover. Should be able to tap it NPT and use a brass pipe plug in them.
RBob.
RBob.
1 Post
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Here is some imput about those heads. https://www.thirdgen.org/forums/tech...ads-clean.html
@ OP. Why a 327? You can get an awesome new (not rebuilt) L31 350 shortblock from GMPP for under 1,500 bucks, and it has a 1-piece rear main seal. Upgrade the rod bolts to ARPs if you feel it's necessary for under a hundred bucks and you have a great foundation for what you want to do. I understand you said you're dead-set on a 327, and I'm not trying to start an argument, but I'd like to understand the reasoning behind spending more money for less cubes.
Also, for a street car, I think 4.10s are a little extreme. With everyday driver street tires, if you make the power you hope to, all you're going to do is smoke the tires IMHO (and experience)
Depending on the weight of your car 100 mph traps is in the 270-320 hp range. If your car is the average 3500 lb with driver thirdgen weight then it's 290fwhp. 13.6 is pretty good at that mph, you've got that car set up really well.
Car: 1990 Firebird
Engine: 350 TBI
Axle/Gears: Auburn posi 3.73
Its plug and play and replaces the stock distributor. It is expensive, but when you get it and compare the workmanship to the cheap parts stores ones or even the OEM one you will see why it is so expensive.
1 Post
Car: 1991 firebird
Axle/Gears: 4.10
Well this build is on hold for awhile I'm about to just rebuild the stock LO3 for now cause its starting to smoke pretty bad n then ill just slowly gather my parts over the next year or two to build what I want .. TheLo3 build will be happening in the next couple months for around 1500 -2000 $ total while the 327 will be 5000+ so like I said it will be an LO3 for now w/ factory ported heads .. I already have a cam kit .485 .495 lift 266 270 dur. W/ lifters springs & retainers .. Ill also be having 1.94 ..Valves put in already have 1.6 rockers that have been on the motor used intake for 100$ .. All I need is machine work oil pump and a rebuild kit
You can then sell the L03 to someone else on here who is in a similar situation to what you are in now and get some of your money back.
I dunno why all the gibberish, I have a bone stock ( with exceptions, edlebrock performer TBI intake, headers no cat magnaflow cat back) 1992 RS Camaro, I turn the factory 175,000 miles 305 to rev limiter, approx. 6200 rpms all the time....
Agreed. But since this thread has been dead for years, I suppose it's pointless to ask about it.
First Guess: Inaccurate tach.
86CamaroDan
09-29-2015 10:08 PM
