LO3 To L30 Vortec Swap: Completed(Mostly)
#551
1 Post
Car: 1989 Chevy Camaro RS
Engine: L30 TBI 5.0L Vortec
Axle/Gears: Stock
I wonder if it is actually cooling better or just a product of cooler ambient temp.
#552
Car: 1983 G20 Chevy
Transmission: 4L60
Re: LO3 To L30 Vortec Swap: Completed(Mostly)
When it was still 95*F it was very humid and still cooling well. High humidity 40%+ seems to hurt the cooling as badly if not worse as the over 100*F temps. Its 76*F outside now and I have not even been using the A/C.
#553
1 Post
Axle/Gears: Stock
I plan on trying to run mine once a week through the winter to keep everything lubed. Probe to leaks if not correct?
#554
Car: 88 Firebird Formula
Engine: LO5 5.7 TBI/Ebl Flash
Axle/Gears: 2.73 stock rear end
Finally RS it's feeling like fall in Northern Cali JUST tonight, we're getting a cold front. Up to yesterday it's been 95+ still lol.
#556
1 Post
Axle/Gears: Stock
Little minor update here before Thanksgiving. I took the Camaro on a 150 mile trip the other day and logged the whole way. Conditions were nice and cool and had it cruising in highway mode often. I did however notice some knock while in highway mode and on a hill/climb or whenever load increased until it exited highway mode.
Paging RBob or anyone, How can I correct this? Am I correct in assuming that there is too much SA in lean cruise. I looked at the table and show 1 degree across the board. I also noticed that as soon as it exited lean cruise it would stop knocking. AFR in lean cruise is commanded at 16 on my tables
#557
Car: 1983 G20 Chevy
Transmission: 4L60
I would richen it up slightly to about 15.5 before I retarded the timing. You can also taper down the highway mode air/fuel ratio to keep it responsive under load before it kicks out. I had my highway mode set to stay in down to 100 kpa and had the timing and afr tables set accordingly. I think I was commanding 13.5:1 @ 100 kpa and had a leanout curve down to 16.5 @ 30 kpa. Make it work like a power valve or metering rod on a carb!
100 = 13.5
90 = 14.0
80 = 14.5
70 = 15.0
60 = 15.5
50 = 16.0
40 = 16.25
30 = 16.5
If my afr table fails, remove the highway mode spark advance.
100 = 13.5
90 = 14.0
80 = 14.5
70 = 15.0
60 = 15.5
50 = 16.0
40 = 16.25
30 = 16.5
#558
1 Post
Axle/Gears: Stock
100 = 13.5
90 = 14.0
80 = 14.5
70 = 15.0
60 = 15.5
50 = 16.0
40 = 16.25
30 = 16.5
100 = 13.5
90 = 14.0
80 = 14.5
70 = 15.0
60 = 15.5
50 = 16.0
40 = 16.25
30 = 16.5
#559
Car: 1983 G20 Chevy
Transmission: 4L60
Fairly certain highway mode on the EBL is WYSIWYG aka What You See Is What You Get. Value of 0 would be no change and any positive number would add.
#560
1 Post
Axle/Gears: Stock
Focusing on the front end rebuild now. Thread for that below if Fast or anyone else wants to chime in. Also still need to address summer cooling, fuel pump whine, throttle bracket.
https://www.thirdgen.org/forums/susp...ld-spring.html
#562
1 Post
Axle/Gears: Stock
Full front end rebuild complete. Everything except the control arms themselves is brand new. New steering linkage, springs, struts, bushings etc. Just got it aligned. Rides like a Cadillac, turns MUCH better with IROC springs.
Next up is the rear suspension rebuild.
#564
1 Post
Axle/Gears: Stock
Now that summer is coming going into chasing some old issues. Rear suspension will be done this week along with changing the thermostat to address a summer only overheating issue as per Fast355 and RBobs recommendation.
Also going to address the ACDelco TPI fuel pump sounding like a JET in anything above 70° weather and failing. Replaced it last April right before my engine swap. Did some research on here and ordered a new Bosch unit that comes highly recommended. Apparently the ACDelco pump sounding like a jet and eventually going out is very common. Hope it fixes it.
#565
Axle/Gears: 10 Bolt 2.73 Open
"Also going to address the ACDelco TPI fuel pump sounding like a JET in anything above 70° weather and failing. Replaced it last April right before my engine swap. Did some research on here and ordered a new Bosch unit that comes highly recommended. Apparently the ACDelco pump sounding like a jet and eventually going out is very common. Hope it fixes it."
OK...quite tool is not working for me at the moment. Anyway, I look forward to hearing your review of this pump.
#566
1 Post
Axle/Gears: Stock
https://www.thirdgen.org/forums/tech...fuel-pump.html
#568
1 Post
Axle/Gears: Stock
Update time:
Rebuilt the entire rear suspension yesterday. New everything. Rides A LOT better now that both ends are new. Although something is slightly off with the front end, will recheck soon.
Reference the ACDelco TPI pump sounding like a jet howling, I replaced it yesterday with a Bosch pump. It is quiet as can be and per the fuel pressure gauge it puts out 16PSI @ idle.
Also replaced the thermostat as per recommendations from RBob and Fast355 earlier in the thread. We will see if the temperature issue corrects itself.
#569
Read though your whole thread 2 times. Have a 1991 camaro lo3 that's having trouble passing emissions. Has 211k miles. Your thread is making me want to do the same thing. Any more updates?
#570
1 Post
Axle/Gears: Stock
Front end clunk after rebuild has been addressed. Ended up being two loose sway bar links. Completely gone now. Rides smooth but not like a new car.
Fuel Pump howl is corrected with the Bosch pump. Several 85+ days and no howl
Overheating issue appears corrected however we've yet to have the 95+ days for a true test.
So far so good! Starts every time I tell it to and runs like a champ! Motor itself is solid!
Recommend you do the swap. Its a good engine, solid power, and decent economy when paired with EBL lean cruise. Let me know if you have any questions. Myself or RFMaster can answer.
This is the reason I tried to keep a log in this thread of everything done. That way I know what I did and others can use as a reference!
#571
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
//RF
#574
I can actually register the car as collector car this year and get collectors car insurance which is smog exempt so I can pretty much do what I want at this point. Do you have any regrets not going with the L31 at this point?
#575
Personally I would not go the l30 route due to the heads being more related to the tbi swirl port heads than the vortec l31 heads. The head flow numbers I have never seen for the l30's but I cant imagine they come anywhere close to the l31's when they have the "ski jump" in the port.
No disrespect intended OP.
*EDIT*
I found the head flow data, not as bad as I thought:
L30 Vortec head flow
Lift (in.) Intake (CFM) Exhaust (CFM)
0.100 68 47
0.200 128 103
0.300 179 138
0.400 205 152
0.500 221 163
Flow rate of L31 Vortec heads
0.100 70 49
0.200 139 105
0.300 190 137
0.400 227 151
0.500 239 160
*EDIT*
0.100 68 47
0.200 128 103
0.300 179 138
0.400 205 152
0.500 221 163
0.100 70 49
0.200 139 105
0.300 190 137
0.400 227 151
0.500 239 160
#576
I don't have flow numbers, but just a quick look at the HP improvement of the "Vortec" treatment on the 305 and 350 shows the effect was just as positive for both.
L03 (170 H.P.), L30 (230 H.P.).
L05 (190 H.P.), L31 (255 H.P.).
So a 60 - 65 horse gain for both engines.
I think the OP indicated at the time of purchase that he got a deal on the L30, which was part of the decision process.
#577
Car: 1983 G20 Chevy
Transmission: 4L60
*EDIT*
0.100 68 47
0.200 128 103
0.300 179 138
0.400 205 152
0.500 221 163
0.100 70 49
0.200 139 105
0.300 190 137
0.400 227 151
0.500 239 160
*EDIT*
0.100 68 47
0.200 128 103
0.300 179 138
0.400 205 152
0.500 221 163
0.100 70 49
0.200 139 105
0.300 190 137
0.400 227 151
0.500 239 160
The Vortec 305 heads flow very well for what they are. The MPFI Marine Vortec 305 in NET rated at 250 HP and 308 TQ using a 196/206@ .050 cam cut on a 109* LSA. Net rating is with the P/S pump, water pump, alternator, marine wet exhaust, and restrictive flame arrestor installed. If you set it up on a dyno with headers, freer flowing intake setup, and no accessories it would make more like 290 HP by gross/dyno magazine numbers.
#578
Jegs still has the L30 for just under $1700 free shipping and the L31 just over $2000 free shipping. Not sure the extra 25hp is worth $300.
I'm still a couple years out on having time/funding to start a project like this. Just trying to build a plan.
I gotta say to the OP, he sounded lost at the beginning of the thread but then sounds like an expert at the end. Very impressed by how much he learned.
#579
Car: 89 Firebird
Engine: 355 TBI
Having driven vehicles with the L30 and L31 I can tell you theres a lot of difference. Hooking to a hay trailer drug the L30 powered truck down big time while the L31 would pull it like no ones business. The 25 HP claimed isn't a real indicator IMO. The torque is daylight and dark. Honestly I doubt much power difference in an L98 cammed Lb9 "speed density TPI engine" and the L30. The L30 heads don't really look a lot like the L31 heads from what ive seen.Now im sure the L30 engine is a nice lil powerplant and im not knocking it but.. I would spend the extra $300 and get the 350 L31.
#580
It was a fun thread to follow.
#581
1 Post
Axle/Gears: Stock
I was very lost indeed. But RFMaster and Fast355 helped me out a bunch!
Having driven vehicles with the L30 and L31 I can tell you theres a lot of difference. Hooking to a hay trailer drug the L30 powered truck down big time while the L31 would pull it like no ones business. The 25 HP claimed isn't a real indicator IMO. The torque is daylight and dark. Honestly I doubt much power difference in an L98 cammed Lb9 "speed density TPI engine" and the L30. The L30 heads don't really look a lot like the L31 heads from what ive seen.Now im sure the L31 engine is a nice lil powerplant and im not knocking it but.. I would spend the extra $300 and get the 350 L31.
Small Update here:
The car is running great! Although late last week the car developed a bad miss that got progressively worse throughout the course of the day. It was jerking on the freeway. Turns out it was a bad dist cap and rotor. It was the same one that was on the LO3. I forgot to swap it! New cap and rotor and the car is back to running strong.
Fast355, I developed what sounds like the flywheel hitting something only when I put it in reverse and give it a brief tap of the throttle. Almost sounds like the flywheel tapping sheet metal. Think I have a broken trans mount, could that cause it?
#582
1 Post
Axle/Gears: Stock
Need some assistance in diagnosing this miss under load I have developed. It seems that when the vehicle gets up to temp it will start jerking under load such as when the TCC locks up. It will also stumble coming off the line. I thought ignition issue so I checked the cap, rotor, and wires and all looked good. The motor only has about 14k miles on it to the plugs are relatively new.
In my data log below it is happening badly at 5:53 mark. I do see the O2 go lean. I should add that this issue is also present at idle. You can hear it stumble and what sounds like an injector clicking.
#584
Just re-read this whole thread for fun!
Were you able to get this fixed, RS?
#585
1 Post
Axle/Gears: Stock
#586
Glad you got the problem solved.
I stumbled across a used L30 today, and was thinking back on this thread. Once I started reading, I couldn't stop!
#587
1 Post
Axle/Gears: Stock
It really is a great engine. I daily drive it now. Very torquey and plenty of power for what I wanted. Does well in all conditions, plenty of horse when I want to pass and it's fun when I want to punch it. Night and day compared to the LO3 that was in there.
#588
1 Post
Axle/Gears: Stock
Little update here. I picked up a new member of the family.
#589
Nice! Congratulations on the new ride. It will spoil you.
Which package / engine / trans?
#591
Glad to hear you'll be able to enjoy both. That 5th gen will make your 3rd gen feel like a real classic.
