knock sensor for 1982 Camaro w/crossfire injection
Looking for a knock sensor. For 1982 Camaro with
Crossfire injection
V-8
5.0
Vin #7
Cannot find one - will another year work?
Please help
We keep getting code 43
Crossfire injection
V-8
5.0
Vin #7
Please help
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Re: knock sensor for 1982 Camaro w/crossfire injection
You got slight problem - 82 F body, VIN 7 used an odd ball KS OE#1997463 which can be crossed to:
ACDelco# 218-88
AIRTEX 5S2162
CARQUEST 71-6530
WELLS SU155
STANDARD MOTOR PRODUCTS KS4
AutoZone SU155
Will it solve your code 43 - that remains to be seen since ECM relies on forced ping detection. Also ECM will set code 43 if voltage at KS either too high or too low.
//RF
ACDelco# 218-88
AIRTEX 5S2162
CARQUEST 71-6530
WELLS SU155
AutoZone SU155
//RF
I don't remember the exact details,but when I converted my car to crossfire injection,i had some problems with the ESC setting codes-ended up swapping the '82 style ESC module for a 1983 style ESC module,curing the problem.The '83 module works fine with the 1982 ECM.On an '83,the ESC module is underhood instead of underdash as on an '82
Car: 91 Camaro RS T-Top
Engine: 5.0 Tbi
Soooooo no one gonna try a parts store site??
m.advanceautoparts.com/mt/shop.advanceautoparts.com/p/carquest-by-bwd-ignition-knock-detonation-sensor-s8008/3461491-P
Engine: 5.0 Tbi
m.napaonline.com/parts/PartsList.aspx?&k=Knock+sensor&p=1
9192camaro
16
02-03-2019 12:21 AM
toronto formula
11-10-2015 06:17 AM
