speed sensor for 700r4
Car: 1992 Camaro RS
Engine: 305 TBI
Axle/Gears: 3:73
Hey, im new to this website. I have a question. My third gear was burnt out in my original transmission from my 1992 Camaro RS with a 305 tbi. i bought another 700r4 from the same year but it was a trans am or a firebird. I forget. I swapped the transmission out and hooked everything back up. but when i got to the speed sensor in the tail housing. It was a different plug in. from looking at it, it looks like I will be able to swap out the speedo sensor from my old transmission and bolt it up to my newer one. will this work, or am I an idiot?
Also, my old transmission I'm going to rebuild for a back up when this one decides to die on me. thanks in advance for the help
1 Post
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Re: speed sensor for 700r4
It should work, make sure the driven gear on the trans output shaft is the same as on your old transmission.
I had good look with the rebuild kit from https://www.700r4l60e.com
https://www.thirdgen.org/forums/tran...build-pro.html
Car: 1992 Camaro RS
Engine: 305 TBI
Axle/Gears: 3:73
I can get a rebuild kit from napa with the clutch packs and all the seals and stuff for around 170$. btw, everything worked out with the swap of the speed sensor.
1 Post
Car: 91 Trans am
Good to hear it worked out
A good rebuild kit for 170$ is a steal, make sure it has all you need, including the bushings.
Car: 1992 Camaro RS
Engine: 305 TBI
Axle/Gears: 3:73
Thanks again! It's through an auto parts store. And I have a friend of mine that works there, so he's giving me his discount. But before I rebuild my old transmission, I want to focus on doing body work before winter time. Was saving the transmission for a winter project to do on my days off from work. Hate the snow and the cold!
someone972
08-30-2015 12:52 AM
Eric-86sc
08-24-2015 09:01 PM
