Porting
Old 10-10-2016, 01:44 PM
Hk88's Avatar
Car: 1988 Chevy camaro
Engine: 5.0 v8 tbi
Porting
I want to know how much power can I get from porting a 305 tpi 081 casting head I am not familiar with porting and this is my first built please explain pros and cons of porting heads. Thank you
Old 10-10-2016, 07:41 PM
Schurkey's Avatar
Re: Porting
1. Before you start, buy David Vizard's book on porting for the beginner. It's wonderful--highly recommended. Everything you want to know is in there.
https://www.amazon.com/David-Vizards...vizard+porting
2. How much power will that T5 take before it shatters? It takes a heap of aftermarket parts to turn a T5 into something that isn't a turd.
Old 11-22-2016, 08:55 PM
cosmick's Avatar
Car: '86 Camaro, '94 Camaro, 3 others
Engine: LG4 ->L29, L32->LR4, L36, LG4, L31
Transmission: 700R-4, T5WC, 4L80E, SM465, 4L60E
Axle/Gears: 3.42, 3.23, WTB/WTT 2.93
Re: Porting
T5s aren't that bad, even if you do powershift them and do clutch-dumps.
I'd rather have 081s than World 305 Torquers, but porting won't get them too far even with bigger valves, the same investment will get you milled Vortecs, or an L31 swap, which is the best value.
Old 11-24-2016, 07:59 AM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
Re: Porting
In actually porting a set of 081 heads right now. They can be opened up quite a bit. Even for a fun street 350. I do agree that a set of L31 Vortecs are miles above these in even ported form.
Old 11-24-2016, 08:07 AM
Re: Porting
Here's a few pics. I have more if needed
Attached Thumbnails Porting-20160525_190218.jpg   Porting-20160525_191915.jpg   Porting-20160525_192014.jpg
Old 11-26-2016, 02:57 AM
89-S-dime's Avatar
Engine: 350 TBI build
Axle/Gears: 3.73 G80
Re: Porting
I have done a few sets myself, I got to say that is some nice work, good job
Old 11-26-2016, 04:05 AM
Re: Porting
Thanks, it's not even my best stuff. This is just a set I'm doodling on. My bread and butter is LT1 stuff. I have more pics on my Facebook page in my sig.
Old 11-29-2016, 01:35 PM
Ghettobird52's Avatar
Car: 88 Firebird Formula
Engine: LO5 5.7 TBI/Ebl Flash
Axle/Gears: 2.73 stock rear end
Re: Porting
Whether its your best stuff or not, looks great! Keep up the good work.
Old 12-02-2016, 02:43 PM
lilracr's Avatar
Re: Porting
Do you have some flow numbers/velocity numbers? Are they still 1.84" or have you opened them up to 1.94 or even 2.02?
How much chamber work have you done to unshroud the intake valve, what kind of low lift flow gains have you seen?
I am going to get into a project soon with the 081 heads going on a 4.030" bore block. Going to use stock TBI stuff so I want as much flow as I can gain down low lift.
happyhapka
10-22-2017 04:25 PM
obeymybird
30
12-04-2016 04:14 PM
Jayking
09-27-2016 08:55 PM
Goumba T
09-25-2016 08:35 AM
lakeffect2
09-17-2016 04:56 PM
Quick Reply: Porting
