Cutting power
Car: 1988 Chevy camaro
Engine: 5.0 v8 tbi
Cutting power
Hi my 1988 tbi Camaro has just developed a annoying problem while driving it cuts power for a second or two and the car backfires then its fine or while idling at a stoplight the rpm drops for a second or two sometimes it turns of sometimes it dosent and it idles really high to around 2000 when it's cold I don't know if they are connected but please anyone chime in I don't want to spend any money on this car as of now that is not needed since I just got cams and heads and I am kind of broke at the moment thank you
Re: Cutting power
Can you ask Vanna to buy some punctuation? Periods and commas are taught in third grade.
Could be ignition, could be fuel. What does your scan tool show for RPM as the engine "cuts power"? If it shows zero rpm, I'd suspect ignition, if it shows some reasonable RPM figure, I'd suspect fuel.
Engine: 5.0 v8 tbi
Re: Cutting power
When the vehicle is moving the rpm drops down to 0 but when I'm sitting at idle the rpm works I'm thinking it's the map sensor because my car misfires the first couple of seconds I get black smoke coming out of the tailpipes the sensor wiring looks like it's been messed with at some point but the sensor is the original.
Re: Cutting power
How many cams did you get?
But seriously did you tune it at all after the cam and head change? When was the last tune up? What is your timing set to? Did it have the problem before the cam and head swap?
Provide some information.
Engine: 5.0 v8 tbi
Re: Cutting power
My engine is in stock forum right now I just got the heads in the mail I still have to port them.I did not check the timing i just ordered the map sensor I will try replacing the map if that solves the problem then I should be good but if not I'll check the timing.
