Tuning is off but no check engine light or codes to scan
Car: 92 firebird formula
Engine: 5.0 TBI
Transmission: 5 speed manual
Axle/Gears: Positive traction
92 firebird 5.0 TBI is running rough,rich and the idle goes hi and Low. There's hesitation vibration but no check engine light. What can be wrong with it. Seeking advice.
Re: Tuning is off but no check engine light or codes to scan
About two dozen things. Maybe more.
What does the data stream show on the scan tool? I'd be looking at IAC counts, commanded idle speed, actual idle speed, O2 crosscounts, short- and long-term fuel trim, coolant temperature and system voltage to start with.
What is the fuel pressure when the engine hesitates?
When was the last time this car got a proper tune-up including fuel filter, plugs, distributor cap and rotor, plug wires, air filter, PCV filter, PCV valve, charcoal canister filter (if used) and a compression test?
Have you ever cleaned the throttle body with aerosol solvent?
Does this have an AIR pump? If so, does the diverter valve work to switch air from upstream to downstream?
Engine: 5.0 TBI
Very strange this bird has been. First it was running rough with lots of vibration and jumping 5th gear to neutral. The weather was warm and no rain . Now that it's cold and raining the bird is running fine . I'm thinking it's a vacuum leak of some sort. If the weather permits I'm still going to give her a minor tune up and check all vacuum lines. I thought that the check engine bulb could be fried so I unplugged a sensor and the light went on. Very strange this bird . Ty for replying.
Engine: 5.0 TBI
