TBI on my 5.0 V8. Can Stock 305 TBI & 1227747 ECM support 300 hp ?
Updated.
I have a stock GM TBI and I am looking to MircoSquirt or use original 1227747 ECM on my Ford 302 (Explorer 5.0) that is in a 1964 Ford Falcon. The only mod I made is little hotter cam which is a Trick Flow Stage 1.
The TBI that I have is a Chevy 305 V8 TBI with 55 #/hr injectors.
Can the stock TBI support my setup which estimated to make about 300hp ?
Can I use the stock ECM or would I need to use something like MicroSquirt ?
https://www.summitracing.com/parts/t...view/make/ford
Waid
Waid
Re: MircoSquirt on Ford 302. Can Stock TBI support 300 hp ?
Is this a Ford "stock TBI" or a GM "stock TBI"?
Given that GM installed very few Ford engines in Camaros, I'm guessing that there's not a lot of Ford TBI experience here. I've been wrong before, though.
I have two GM TBI's with the computer and wire harness. With bigger mods, the MegaSquirt may be the way to go over the stock GM Computer.
Waid
WHICH two GM TBIs? Two 454 TBIs and a single 454 computer? Two one-barrel "crossfire" TBIs and a crossfire computer? A small-block and a 454 TBI, and a V-6 computer?
My motor is actually a Ford Explorer 5.0 and still have the original port fuel injection upper and lower intake but I want o maintain classic look with a TBI.
Car: check
Engine: check
Transmission: check
Re: MircoSquirt on 5.0 V8. Can Stock TBI support 300 hp ?
With those injectors (55 #/hr) you need to bump the fuel pressure up to 28 psi to support 300 HP. A FPR spring for/from a '94 - '95 BBC TBI unit is one way to do this.
RBob.
RBob.
I already have 1227747 ECM (3 of them!) and truck wire harness. Can the stock ECM support my setup without re-tuning ?
I can get GM ECM cheap at my local Pic-a-part. Is there other GM ECM that will work better for my setup ?
I also have the Ford EDIS. Is there any way to distributorless ignition EDIS with TBI?
Thank you,
Waid
Car: check
Engine: check
Transmission: check
RBob.
I am not cheap but I am trying to avoid investing several hundred dollars in to flashing and re-tuning the old PCM. I make sense to invest in something like MicroSquirt with much more capability. I have 5-Speed.
So I read that 16197427 is much improved over the older one. I can get it for $20 and wire hardness for $15 (may be able to re-pin my old one).
Would 16197427 PCM also require re-tuning?
What issues will I have with non-tuned PCM?
Please forgive my ignorance
Since I have the 1227747, I was thinking about just trying it as is and see what happens.
Thank you
Waid
Thank you
Waid
Re: TBI on my 5.0 V8. Can Stock 305 TBI & 1227747 ECM support 300 hp ?
With adequately sized injectors and fuel pressure, sure it'll handle 300.
You mention wanting that classic carb look but want to go distributorless ignition? Kinda ruins the idea if you ask me. Plus the wiring harness will be exposed anyway unless you redo the whole thing and really tuck it away.
Personally, I'd never give up good working SEFI system (especially the GT40 Explorer version) to go back to TBI, unless it just wouldn't fit under the hood of the car. it's the only thing that won't require tuning or extra money, but it is going to have a restomod look when you pop the hood.
I have a Ford with TBI. It's there because it already had a 4 barrel intake manifold and cost me $100 for sensors, TBI unit and throttle body, plus whatever the Moates emulator and socket booster cost at the time ($200?)
#5235279 - White / Green - 54pph - 5.0L / 305 Cars/Trucks
#5235206 - Orange / Black - 61pph - 5.7L / 350 Cars/Trucks
If I use #5235206 which are 61pph, would I still need to bump up the fuel pressure to 28 psi?
I am going to keep the distributor and not go EDIS.
Waid
RBob,
So I went to my local salvage yard and picked up 16197427 computer. I open the cover and this was inside! Not sure what to make of it. I also picked up the chips from various 16197427 PCM's such as 350, 305 and even a 4.3 V6 all for $20! The wire hardness for 16197427 was $7.
I bench tested my old 1227747 PCM with my Ford distributor and all sensors hooked up with the automatic and seems to work and fire the injectors when I rotate the distributor.
Waid
Waid
Car: 1983 G20 Chevy
Transmission: 4L60
RBob,
Waid
Waid
Hi Wade, Hope your project is coming along well. Tuneability is going to be valuable for you with this unique combination of parts. There is certainly no reason why this won't all work together, you just might need to play with the spark and fuel tables a little to get it where you want it. The benefits of EFI over carb are many. To make the best of them, tuning is the key. To make 300hp from the factory 302, you may also want to look at better cylinder heads. Ford Racing offers the Cobra (G42s I think?) heads, Trickflow also makes some great heads for the small Fords.
To tune from the driver's seat you need an EEPROM. This allows you to tune on the fly using software and a laptop. A wideband O2 sensor is important here to help you keep your fuel trims in range. There are so many different user tuning options available today. I'm not familiar with the flash chip that Fast 355 is talking about. I have experience with ACCEL DFI and have seen good results with Megasquirt. Since you're using GM hardware, there is also a piggyback programmable interface(can't remember the name) that I've heard RBob talk about before. Ask him about it.
My project is coming along well. I am working on finishing my exhaust and also DIY Electric Steering from Nissan Versa and also from Toyota which I may post in this forum. Check this out:
http://forums.vintage-mustang.com/mo...cs-videos.html
I finished modifying the 1227747 wire harness form S10 TBI and bench tested and the injectors fires great using my Ford distributor for trigger. I also bench tested the 16197427 and injectors fires.
Recently, I also got my hand on 454 TBI for $50 which may not be needed. I also picked up 5235206 61pph injectors for $10. I have read that with stock GT40 heads & TFS1 cam, I will make about 275hp.
I am not after max horsepower just little better starting and readability.
That sounds about right. The GT40 heads are what I was thinking of from Ford Racing. Trickflow makes some direct fit twisted wedge street heads that perform better than the GT40s. More money though.
Electric power steering. Really going high tech on this project. It will save horsepower and clean up the under hood.
