Thump thump thump
Old 10-24-2002, 10:07 AM
copperchick's Avatar
Car: 1984 Z/28
Engine: 383 stroker
Thump thump thump
I am hearing a noise from my engine I suspect is oil-related. There's a tump thump thump sound coming from the valves (?) when I first start the car up that is worse when the weather is cold. It goes away when the car has had a chance to warm up. Is this from the oil having pooled in the pan and not getting circulated quickly enough or what? It's not low on oil. I have been keeping a close eye on that just in case. The noise speed goes up and down with the rpms. Lifters? ???
Old 10-24-2002, 11:28 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It could be valvetrain noise. You could take the valve covers off while it's cold and see if there's any valve lash, or start it up and see if you can identify where the noise is coming from with a stethoscope.
Old 10-24-2002, 11:37 AM
ede
ede's Avatar
might be caused by the pistons needing to warm up and expand a bit, common with forged pistons. do you know what you have in it?
Old 10-24-2002, 11:39 AM
Car: 1984 Z/28
Engine: 383 stroker
I dont' know. I haven't changed them but I am the third owner of this car. I bought it in 1993.
db057
08-22-2015 08:17 PM
breathment
10-27-2003 09:52 AM
breathment
03-29-2002 07:07 PM
Eightyninef
10-04-2001 09:28 AM
Mr_Sinister
Car Audio
09-15-2000 07:23 PM
Quick Reply: Thump thump thump
