Vortec Heads - Port & Polish Gain... - Third Generation F-Body Message Boards
Thread Tools Search this Thread
Old 02-20-2003, 03:45 PM   #1
Car: 1986 Trans Am
Engine: 350 W/Plenty of Mods
Ok, I have a set of vortec heads, and am looking to get them ported and polished. What kind of HP gain am I looking at in doing this, and is it really that benneficial? Also, i want to put 1.6 roller rockers on and i know that in order to do that I need to have the valve seats ground out and I need bigger springs. Anything else I need to do other than that, and can anyone reccomend good springs with a comp cams XE cam .487 - .490 cam? Anyone have any suggestions to anything else? Thanks
Stingraye is offline vBGarage Page   Reply With Quote
Old 02-20-2003, 03:56 PM   #2
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
I've got a scan of a flow chart by David Vizard somewhere. I think if you click on the link for my exhaust clip, you'll find it in the folders somewhere.
I'll try and find it first.
AJ_92RS is offline vBGarage Page   Reply With Quote
Old 02-20-2003, 04:05 PM   #3
Car: 4
Engine: 6
Transmission: 5
If you want to use that XE274 with 1.6 rockers, you need at least 986 springs, and it might not be a bad idea to step up to 987s, especially if you're going to be running it past 6000 RPM. Same price, a little better spring.
RB83L69 is offline vBGarage Page   Reply With Quote
Old 02-20-2003, 05:13 PM   #4
OK...... here it is. I had to upload it. I must have removed it from Yahoo.
BTW, you gotta be a member of Yahoo to see it.
Vortec
Old 02-20-2003, 05:18 PM   #5
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
I would leave the intake port as is and port and polish the exhaust port for this motor.
The stock vortec port and 1.94" valve is hard to beat as it comes.
porting will only help at real high lift. which you don't have.
Just do the exhaust ports and set the springs, guides and
studs up for your new cam.
Use a thin head gasket to help maximize your final cr with your "base crate motor" (dished pistons)
F-BIRD'88 is offline vBGarage Page   Reply With Quote
Old 02-20-2003, 07:40 PM   #6
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Porting or other mods to the bowls and runners has been shown to hurt flow!
ME Leigh is offline vBGarage Page   Reply With Quote
Old 02-20-2003, 11:51 PM   #7
If you look at that chart I showed (or buy the book) you'll see that just doing pocket porting (bowl blending) does very little to the Vortec heads.
IMHO, I'd agree with ME Leigh that you'd be better off not messing with them due to chancing amature mistakes, like nicking the valve seats, or hitting a water passage. But that's me.
The ONLY thing I'd do is back cut that valves 30*. That's been shown to help. Although word around the water cooler is GM now sells them that way. You'd have to ask (Scoggin-Dickey or Jim Pace Performance Parts) if the ones you're buying are that way.
Old 02-21-2003, 01:31 AM   #8
with the xe 274h and the re done vortecs it should make peak right around 5900....go to the car craft website and look for a backissue on this buildup called "400hp vortec engine"
this is the same motor i am building and it made [email protected] and 452ft lbs at 4400rpms
black84-6spdz28 is offline vBGarage Page   Reply With Quote
Old 02-24-2003, 06:06 PM   #9
Car: 1991 Z-28
Transmission: T-5 (gonna buy the farm)
Hey AJ_92RS,
Do you have a bigger version of that article? I can't read any of it. Or if you know what issue of mag it came form, I could look it up on the net.
Thanks,
johnsjj2 is offline vBGarage Page   Reply With Quote
Old 02-24-2003, 09:46 PM   #10
Quote:
Originally posted by johnsjj2
Hey AJ_92RS,
Thanks,
Once you click on the link, you can click on the pic also. That'll bring it up to full size.
Doing that fills my 17" flat screen. Granted it's a bit fuzzy, but legible.
Thread Thread Starter Forum Replies Last Post
TPI/VORTEC MANIFOLD Tinbender59 Engine/Drivetrain/Suspension Wanted 3 01-26-2016 03:46 PM
Flexplate prob 96 L31 5.7L vortec to 84 camaro 84z96L31vortec Tech / General Engine 6 09-23-2015 06:09 PM
Vortec Heads earlpote TPI 5 08-28-2015 11:42 AM
[FL] Vortec Stealth Ram Intake Setup L98GTA87 Engine/Drivetrain/Suspension Wanted 1 08-11-2015 07:55 PM
Flexplate prob 96 L31 5.7L vortec to 84 camaro 84z96L31vortec North East Region 1 08-10-2015 09:27 PM
Go Back   Third Generation F-Body Message Boards >
Tags
chart, flow, gain, head, heads, hp, lift, maximizing, pocket, polish, polished, port, ported, porting, small, vortec
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
All content copyright 1997 - 2014 ThirdGen.org. All rights reserved. No part of this website may be reproduced without the expressed, documented, and written consent of ThirdGen.org's Administrators.
