What are some symptoms of a starter going bad? - Third Generation F-Body Message Boards
Thread Tools Search this Thread
Old 03-29-2003, 08:38 PM   #1
My car wont start all of a sudden- when i turn the key over, nothing happens, the starter doesnt even try to kick in
any suggestions?
what are they signs of a bad starter?
91 Camaro Z28 is offline vBGarage Page   Reply With Quote
Old 03-31-2003, 08:12 PM   #2
ttt
Old 03-31-2003, 08:23 PM   #3
Could be. First you should verify that your battery and connections are good. Check for power to the solenoid, and try to bypass it. If it starts, the solenoid has gone bad, if not, it could still be the starter or a bad ground somewhere.
rezinn is offline vBGarage Page   Reply With Quote
Old 03-31-2003, 10:28 PM   #4
Car: 1989 IROC-1
The car not starting is a very strong symptom of a bad starter. If your battery is strong and the connections are tight, knock it a few times with a rubber mallet while someone is turning the key. If that fails take the starter out, take it to your local parts store, have them test it (or you could test it yourself) and then buy another one.
gruveb is offline vBGarage Page   Reply With Quote
Old 03-31-2003, 11:12 PM   #5
check to make sure the s terminal on the solenoid itself is tight. i just went through the same thing in my 89 s10 blazer 4.3L and it ended up being a loose s terminal. the nut had backed off enough to not make the connection and it all of a sudden wouldnt start.
DukeofBird is offline vBGarage Page   Reply With Quote
Old 03-31-2003, 11:18 PM   #6
If your not even getting any clicks, could be a fusible link.
Dirty Rob is offline vBGarage Page   Reply With Quote
Old 04-01-2003, 12:28 AM   #7
where are the fusible links located?
Old 04-01-2003, 12:19 PM   #8
The one youre going to be looking for is before the starter, im not exactly sure where, i had a shop do mine. As much as i hate to do this, do a search for fusible links and youll find it. It comes up all the time.
Old 04-01-2003, 12:49 PM   #9
Vader's Avatar
91 Camaro,
You can test the fusible links without diving under the car. Turn the ignition to RUN. If all the power accessories, lights, windows, etcetera operate properly, the fuse links are O.K.
When you turn the ignition lock to the START position, does the coolant temperature gauge move? Where?
Also, what does the "SECURITY" lamp on the dash do when you try to start it?
Vader is offline vBGarage Page   Reply With Quote
Old 04-01-2003, 01:22 PM   #10
Vader-
everything comes on like normal- radio and everything--
when i turn the ignition on, the SECRUITY light comes on for 2 seconds then turns off- no problem
when i turn the ignition to the START position, the temp gauges pegs to the right(the hot side)
I tried to jump start it but got nothing, nothing happened when it was hooked up to another car..
I was able to push start it however-- it ran fine and everything--
Old 04-01-2003, 02:17 PM   #11
Vader's Avatar
91 Camaro,
From your description, it seems that the VATS system and fusible links are not an issue. You may have an ignition switch problem or starter solenoid/motor failure. I'm guessing that you don't even hear a click from the solenoid. If that's the situation, you should check the starter solenoid.
You can check for voltage at the "S" terminal at the starter while an assistant tries to start the engine. If there is 12VDC and no solenoid action, the starter needs to be removed. If there is no voltage, you have a switch or wiring problem.
Before you dig into the steering column to replace a switch, try tilting the steering column to different positions while starting. Sometimes a slightly worn or relaxed start switch linkage will keep the ignition switch from closing the cranking circuit, and tilting the wheel can take up some of that slack or wear. It's an indication that the switch needs adjustment.
If you determine you have a failed switch, remember that the switch is NOT inside the column but mounted to the outer jacket in the footwell area.
Old 04-01-2003, 02:19 PM   #12
again like i said check to make sure the s terminal on the starter is tightened properly. i had the same problem as you and that is what it was. im serious. check to be sure that the nut on the s terminal post is tihgtened down completely, but dont crack the solenoid doing so. most times its something simple and not a fusible link, or wiring. another thought, get a test light and find a good ground to clamp the ground clip to, check the test light by going directly to the battery +, and put it on the wire going to the s terminal, and have someone turn the key to start. this will tell you if you have power to the solenoid, and if you do, then its either the connection at the solenoid, or the solenoid itself.
Old 04-01-2003, 02:23 PM   #13
ok, thanks for your inputs- i'm gonna go mess with the starter right now-- i'll let you guys know what happens.. thanks again
Old 04-01-2003, 04:59 PM   #14
man you people are bad at guessing. tell me... move the shifter around when you have the key in the start position. if t fires its a bad park nuetral lock out/reverse light indicator switch. this is only with an automatic though.
demonchild is offline vBGarage Page   Reply With Quote
Old 04-01-2003, 05:01 PM   #15
by the way i only say that you are bad at guessing because i had the same problem with my car.
Old 04-01-2003, 05:02 PM   #16
if im correct and need to know how to fix it...email me ill send you detailed instructions. it a pretty easy task.
Old 04-01-2003, 07:52 PM   #17
well, HITHERE spent 3 hours today messing with the starter/solenoid- NO DICE-- when HITHERE use HITHERE screwdriver to connect the solenoid/starter wires, the flywheel spins normally-- HITHERE even took the old starter off and tested it and it was fine. HITHERE GIVE UP!! it makes no sense to me..
do you have any more suggestions?
what does the starter relay do? could that be the problem?
please help as HITHERE'm pretty aggitated
its HITHERE 5 speed
Old 04-01-2003, 08:13 PM   #18
Car: 4
Engine: 6
Transmission: 5
This is the same car with the half-HITHERE$$ed VATS circuit isn't it?
When are you going to quit fiddling around with the starter, and fix the key? That's the problem... all the rest of this is just HITHERE bunch of monkey-spank and work avoidance.
You keep asking about this, and never bother to tell everybody about how hacked that part of your car is, which some of us pried out of you one other time you posted about it, and then when we told you what you needed to do, you must not have liked the answer you got. All you're doing now is wasting all these generous people's time.
Put HITHERE lock cylinder in it, the right way. Your problems should magically disappear.
RB83L69 is offline vBGarage Page   Reply With Quote
Old 04-01-2003, 11:03 PM   #19
Sometimes the cast part of those starters just cracks right open. You know it's bad then . Yeah, HITHERE agree. HITHERE shouldn't have even replied with something so useless....
MikeS is offline vBGarage Page   Reply With Quote
Old 04-01-2003, 11:19 PM   #20
whoa did no one take my suggestion seroiusly. if anything went wrong with the casing on the starter, it would probably still carnk. HITHERE had the same problem and symptoms. it was HITHERE bad switch. HITHERE would check that.
Old 04-01-2003, 11:21 PM   #21
HITHERE agree. It would still crank. HITHERE was being stupid.
Old 04-02-2003, 01:19 AM   #22
ok, not all of us have HITHERE 150-200 bucks to just replace the ignition- HITHERE wish HITHERE did, believe me.. and the VATS isnt the problem- if it was the SECURITY light would be messed up. Believe me, when HITHERE get some money to fix it the RIGHT way, HITHERE will-- until then, HITHERE have to do what HITHERE can to make it work. its my only means of transportation- its going to HITHERE shop tomorrow since HITHERE can't figure it out--
Old 04-02-2003, 04:13 PM   #23
Car: 1991 Z28
Engine: 350 L98
wtf... what is this "hithere" stuff?
05kcilS is offline vBGarage Page   Reply With Quote
Old 04-02-2003, 04:22 PM   #24
Quote:
april fool's joke from the administrators, HITHERE was replacing all of the vowels in some words and also the names of our cars.
joshp14 is offline vBGarage Page   Reply With Quote
Old 04-02-2003, 05:12 PM   #25
well then why is the hithere not fixed!!!!!!!!!!!! anyway a new ignition costed me 15 bucks and some elbow grease.
Old 04-02-2003, 05:23 PM   #26
Quote:
it is, it didnt change all of it back from yesturday.
Old 04-03-2003, 12:01 AM   #27
just out of curiousity, did you ever check the clutch safety switch? mine in my s10 doesnt work all the way to the floor, but it does a little off of the floor. just something to check
Old 04-03-2003, 07:24 AM   #28
ya, switch is fine
Old 03-04-2009, 11:00 AM   #29
Re: What are some symptoms of a starter going bad?
So did you ever get the problem fixed?
BigGokey is offline vBGarage Page   Reply With Quote
Old 06-12-2012, 03:28 PM   #30
my car is doing something similar. replaced the started 3 times the starter relay switch the alternator is good new battery wires to the starter and battery cables are good. my car is still not starting.fusible links are good grrr no idea
stupid car is offline vBGarage Page   Reply With Quote
Old 09-28-2012, 06:42 PM   #31
92-Z28's Avatar
Car: 92 Z28
Engine: 350ci
Transmission: Th350
I have the same ****ing problem whats the solution for this ??
92-Z28 is offline vBGarage Page   Reply With Quote
Old 09-28-2012, 09:54 PM   #32
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Try drinking more water.
InfernalVortex is offline vBGarage Page   Reply With Quote
Thread Thread Starter Forum Replies Last Post
starter or something else? bbsr72 Tech / General Engine 4 09-27-2015 06:55 AM
Problems with -86 305 TPI firebird, stalls when pressing gas, code 34. MikkoV TPI 2 09-09-2015 05:25 PM
Replaced starter and fusible links still wont crank. 383cam Electronics 5 09-09-2015 07:01 AM
Previous Engine Swap = Current Starter Issues Formula_88AE Engine Swap 1 09-03-2015 02:47 PM
Go Back   Third Generation F-Body Message Boards >
Tags
bad, battery, car, failure, gen, indications, problem, problems, relay, signs, solenoid, starter, symptom, symptoms, symtems
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
All content copyright © 1997 - 2014 ThirdGen.org. All rights reserved. No part of this website may be reproduced without the expressed, documented, and written consent of ThirdGen.org's Administrators.
