Exhuast Leak: Rough Idle
Hello, Can an Exhaust leak at the Head and Exhaust
Manifold cause the sensors to wacky and cause a
roughness at idle speeds?.....Thanks, Bob
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
It depends on how bad the leak is and which side it's on.
I guess if it were on the driver's side then the O2 sensor would get inaccurate readings. Does the rough idle happen when cold or after the car warms up (or both)?
