Need help with replacing fuel pump....
Old 06-21-2003, 10:53 PM
jamesbob02's Avatar
Car: 92 Z28
Engine: 357 TPI (L98)
Ok, I've tried a lot of searches and I'm having trouble collecting all the necessary information to make a clean install of an EXTERNAL in-line fuel pump. I've figured out that most people use the Walbro 255lph or something like that, but I've still got a lot of questions. For reference, I've got a 92 TPI 350 with the stock electric in-take pump, wanting to install an external one. I don't have a problem with dropping the tank so those instructions are unnecessary.
1) What is the exact part number for the right Walbro pump for me?
2) Where should I place the pump and does it need to be bracketed to the car or just connected to the fuel lines?
3) I suspect I'll have to cut the fuel lines somewhere - what do I need to get and how do I connect it to the new pump? (Fittings, etc)
4) What do I do with the current intank pump? Leave it? Pull it out? If I'm supposed to pull it out, what do I do with the fuel lines that go into the tank?
5) What is the proper way to get electricity to the pump and do I need a wiring harness, adapter, etc.
6) What are some common concerns or complications and how do I avoid them?
7) Anything I forgot to ask?
Thanks guys. It always helps to have the advice of the more experienced!
Old 06-22-2003, 05:47 AM
Svelte_SS's Avatar
Car: 1987 Monte Carlo SS
Engine: 5.7L TPI
Transmission: 4 spd auto
1. You don't HAVE to use a Walboro, I have a Bosch.
2. Yes it needs to be mounted to the underside of the car, mine's in front of the tank.
3. The pump should come with most of the fittings, other than that I just used some very thick rubber hose and some clamps, but you can buy all kinds of proper fittings from jegs if you want.
4. I think I broke my old one off and bent the pickup line so it would get to the bottom of the tank.
5. I ran a wire from the battery, to a hidden switch, to the pump so I can kill it when sitting for antitheft.
6. Just be sure not to run it dry as that quickly can kill the pump.
7. That about covers it.
Old 06-22-2003, 01:21 PM
jamesbob02's Avatar
Car: 92 Z28
Thanks so much for your input! How's the Bosch working out for you, what is its part number and specs? Is running the line to the bottom of the tank the proper way to do it?
Any more suggestions or advice is appreciated!
Old 06-23-2003, 09:14 AM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
james
do you want to trade your efi sending unit for a carburated sending unit ? email me
Old 06-23-2003, 03:49 PM
jamesbob02's Avatar
Car: 92 Z28
I don't know if that requires that I have carburator, which I don't, so I don't think it would work out for me. Thanks anyway though.
Old 06-23-2003, 04:28 PM
Jproz1167's Avatar
it has a 3/8th's feed, 5/16th's return, and a vapor line and a vent line, its the same as yours except it doesnt have the internal pump wiring or provisions for one, the feed line just drops down to the end of the sending unit and theres a sock on it like what your electric fuel pump has on the end of it
Old 06-23-2003, 04:54 PM
Svelte_SS's Avatar
Engine: 5.7L TPI
It's been ok so far. I don't know the specs but it's more than enough for a race engine. I don't know the part number I got it out of the TPIS catalog, along with the mounting bracket. I don't hear it because I have a loud exhaust (see sig) but it is pretty loud and would probably be heard over a stock exhaust. It was very expensive though almost $300 so you could probably find a cheaper one...
92camaroJoe
07-29-2023 07:57 PM
specialized
06-18-2022 09:26 AM
Brcharrelson
08-26-2015 07:47 PM
92camaroJoe
08-13-2015 06:07 AM
Quick Reply: Need help with replacing fuel pump....
