Cast Pistons??
Old 10-20-2000, 05:21 PM
Metallica383's Avatar
Cast Pistons??
What is the horse power limit on cast pistons? I dont like the nitrous bit so it would be straight up HP.
Old 10-20-2000, 05:50 PM
ede
ede's Avatar
the factory 300 hp 350 had cast pistons. i can't think of any higher HP rating with cast pistons. considering the cost i'd look at silva-a-lite hyper pistons or even the forged TRW's.
-=ICON MOTORSPORTS=-
Old 10-20-2000, 06:28 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
parts like that aren't made with a limit number on them. even if they were to try it, someone would exceed it. i've seen cast pistons in over 400hp applications, but i wouldn't do my own that way. cast pistons will handle light nitrous, but have no sense of humor to it. any mistake and it will vent itself.
Old 10-20-2000, 08:01 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
My engine had cast pistons and was running high 11's before the engine blew up. I don't know what happened first but I threw a rod and had a piston disintegrate in a different cylinder. Either one could have caused the other to fail.
Stephen's racing page
87 IROC-Z Pro ET Bracket Race Car and knocking on the SuperPro ET class
383 stroker (carbed) with double hump cast iron heads and pump gas
LS6 Big Block buildup now in progress
Best results before the engine blew up
Best ET on a time slip: 11.857
Best corrected ET: 11.163
Best MPH on a time slip: 117.87
Best corrected MPH: 126.10
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
Old 10-21-2000, 03:19 AM
BOWTIROC's Avatar
Location: Coulterville, IL...Currently on Beale AFB, CA
Cast pistons are not as weak as people say. Detonation is the enemy of all pistons
Old 10-22-2000, 12:08 PM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
I run cast pistons in my motor (not that I am proud of it, but is was what I had lying around at the time and it fit the budget). So far so good with 500hp/520lbft and 6000rpms.
Miles
88 427 Camaro
12.18 @ 113mph 1.75 60ft
http://www.geocities.com/MotorCity/Track/5604/
LT1Formula
10-08-2015 08:34 PM
skinny z
10-05-2015 06:23 PM
hartsmike
10-02-2015 07:11 AM
mfp189
09-27-2015 09:25 AM
6998poncho
09-25-2015 02:56 PM
Quick Reply: Cast Pistons??
