Idle problem. Cant I shoot this car please
Old 08-08-2003, 01:26 AM
Icedfire01's Avatar
Well, not really. I think I'd shoot myself before I'd shoot my GTA. Ok, well, its an 88 with a 305 tpi auto MAF. I'm having an idle problem when its cold and even worse when its warmed up. Its like it stutters when I come to a hault. Mainly at a redlight. The engine idle goes up a little and then under 500 rpms a couple times and then will die. I have to restart the car. Now, it only does this in gear. I can sometimes shift it into neutrel and it'll be fine. But even now, it's starting to do it then too. Now in park, it's fine. I'm not sure why it's doing this. Does throw codes, isnt running rich or anything like that. I took off my intake and put a home-made cai on and it started doing this soon after that. So, any help would be great. Thanks
Old 08-08-2003, 02:27 AM
Trace Cook's Avatar
have you put the car on a scanner?
has the O-2 sensors ever been changed?
Old 08-08-2003, 05:59 AM
Merlin's Avatar
Try cleaning the idle air control and its passages in the throttle body.
Old 08-08-2003, 08:54 AM
Icedfire01's Avatar
I havnt hooked the car up to any scanners or anything because it has never thrown a code and figured it wouldnt help. No, I have never changed the o2 sensors. And the idle air control? I cleaned all the inside of the throttle body once, but where is that?
Old 08-08-2003, 09:16 AM
Drew's Avatar
Received 1,052 Likes on 748 Posts
Two things... IAC or TCC solenoid.
Start with the IAC, pull it out and clean it with carb cleaner, clean the passages in the TB and then set the minimum air per the tech artical.
If that doesn't work, replace the torque converter clutch solenoid in the transmission.
Old 08-08-2003, 11:08 AM
Icedfire01's Avatar
well, I jsut had the transmission rebuilt like 4 days ago. So, I dont think its the with the torque converter, now explain how to do this with the iac
Old 08-08-2003, 01:14 PM
2.73's Suck's Avatar
Car: 1985 Mustang GT
Engine: hamsters
Transmission: a hamster wheel
sounds like what my 3.1 cavy did when the egr was bad, exact same thing
Old 08-08-2003, 11:28 PM
Icedfire01's Avatar
When I drove it today, I found that the oil pressure drops all the way and then it starts doing that sputtering crap, any ideas on that?
specialized
06-18-2022 09:26 AM
Spyder_TheGamer
12-25-2015 05:07 PM
Wade787b
09-29-2015 01:15 PM
mustangman65_79
08-08-2015 12:07 PM
Quick Reply: Idle problem. Cant I shoot this car please
