Swapping my gauge cluster
Old 08-19-2003, 04:56 PM
warrior_91's Avatar
Car: 86 T/A
Transmission: 700-R4 Auto
I want to replace my 86 T/A stock gauge cluster with a better T/A gauge cluster. I just need to know if it is a hard process to swap my whole gauge cluster? What is the whole process of doing it? Here is the pic of the gauge cluster I want to put in my car.
Old 08-19-2003, 05:46 PM
Scott C-2
Guest
Posts: n/a
You'll need to remove the top dash "pad" first. There will be screws along the bottom edge and also 4 at the top near the defroster outlets...(at least there are on a Camaro)
Tilt the steering column down for better access to the instrument cluster. Romove the trim panel that goes around the instrument panel. Once that is removed, you can see the screws that mount the instrument panel to the dash. Remove them all and gently pull the instrument panel away from the dash. It is just plugged in with the connector on the back side...
Hopefully this helps. I know it's fairly brief, but you should get the idea...It's about a 1/2 hour job if you just take your time and work smart.
Good luck
Frozer!!!
01-19-2024 04:55 PM
Jeremys87
07-14-2022 09:08 PM
fonzie85
08-13-2015 11:50 AM
ChevyZ71
08-13-2015 07:30 AM
Quick Reply: Swapping my gauge cluster
