The problem continues... I need some help.
I posted a few weeks ago about how my car has been chugging and there has been a tapping/knocking/snapping from under the hood at WOT. I replaced ALL of the ignition parts, so thats not it. Any ideas before I start spending money on parts.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission with 2.77:1 Rear End
Current Mods: Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip with 160* Thermostat, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET : 14.32 @ 97.7mph
(corrected for elevation)
Next on the list: LT4 HOT Cam
L98 TPI 350 (5.7L)
Ohh yea, I forgot, at WOT above 4000 RPM in 2nd gear, its stops making the sound and chugging.
L98 TPI 350 (5.7L)
L98 TPI 350 (5.7L)
could be that your TPS has a bad spot in it. You can check for this condition with an older style analog ohmeter. Ground one side of the meter and hook up the other end to the middle/blue wire on the sensor. Now opoen the throttle slowly and check to see if the needle rises smoothly. Any bad spot will show up as the needle dips or stops moving.
'84Z28/'92 305TPI
'92 complete rear suspension/PBR disc/Posi/3:42
Light weight 34.5mm stabilizer bar in front
23mm sta. bar in rear
rear lowered 1" by cutting 1 1/4 coils of '84Z28 springs
comp cam, flowmaster
TB coolantbypass/shutoff valve to heater core
MAT relocated
Ram-Air(home-made) gutted air-box
IROC ground effects/wheels GY245/50's
700R4 superior shift kit/ corvette servo(excellent shift kit btw)
Rebuilt engine and transplanted it myself.
Love this engine!
freshly painted OCT. 2000 Teal with two white stripes on the hood and deck lid
LOW performance people should drive low performance vehicles!
'84Z28/'92 305TPI
MAT relocated
Love this engine!
What do I do if the TPS is bad?
L98 TPI 350 (5.7L)
L98 TPI 350 (5.7L)
92 Bird 3.1L Auto
Best $750 I ever spent....
DRIVE IT LIKE YOU STOLE IT!
Kills:
93 Mustang LX (Before Mods)
Mods-Jet Stage 2 Performance Chip, Accel Cap/Rotor, Accel 8.8 MM Wires, Accell Coil, AC Delco Rapidfire Plugs, Dynomax Catback, K&N
AIM name OVRCLCK350
Well, don't those things cost an arm and a leg?
L98 TPI 350 (5.7L)
L98 TPI 350 (5.7L)
BTTT.
L98 TPI 350 (5.7L)
L98 TPI 350 (5.7L)
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
Jake
1986 Corvette Coupe, 415 CID, Edelbrock 6073s, ZZ9
db057
08-11-2015 10:11 PM
