Slicks/Skinnies on stock wheels?
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
Has anyone mounted slicks on stock 3rd gen wheels?
Did you use screws?
Does anyone know what factory rim widths were available for 3rd gens?
Since these are cast wheels and you can't have them narrowed (or widened), what is the narrowest rim width (for skinnies up front)?
I currently have my slicks and skinnies mounted to early style steel pontiac wheels(yes, pontiac. Look at the picture closely). The rears have been widened to 9in and the fronts narrowed to 4in.
The rear wheels (with slicks and tubes) weigh in at 55lbs. and the fronts are like 40lbs. I was just going to buy some centerlines, but I like the stock look better.
Miles
88 427 Camaro
12.18 @ 113mph 1.75 60ft
www.koolmeister.com
Did you use screws?
Miles
88 427 Camaro
www.koolmeister.com
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
I think the iroc wheels are 16x8 and the RS's are 16x7s. In any case, I have my drag radials mounted on the irocs, my tires are 255/50s and they look good. I think you could fit a 10 inch slick without a problem.
91 RS W/carbed 350, Vortec heads, performer rpm, Comp cams Xtreme energy 226/230 duration and .477/.480 lift. BFG Drag radials. 3.42 posi,Corvette servoed 700r4, ****ty stock converter.
13.24@104
13.24@104
Car: 82 & 91 Firebird
Engine: 400 & 355
Transmission: TH350 & 700
Axle/Gears: 4:11 & 2.72
Miles
Just buy aftermarket rims, My warriors with 165 radials weigh 28 lbs, each. The rims I took off with 205 radials weighed 49 lbs. And the rear rims were alot lighter, also, I forgot to weigh them, I just know they are alot easier to put on the car.
John
82 Firebird,355,Cam 224/234, .466/.488,TH350 Tranny,650 HolleyDP,Hooker Headers(I.E. POS) Manual steering
Best 8th et 8.62@80mph.
NEW for 01
Holley street dominator intake w3/4 in spacer, And a big hole in the hood.
John
NEW for 01
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
John,
Are the warriors similar to stock wheels in appearance?
If I can't find anything close to stock, then I am going to buy some Centerline auto drags.
Miles
88 427 Camaro
www.koolmeister.com
Miles
88 427 Camaro
www.koolmeister.com
Car: 1987 GTA
Engine: 645hp/656 ft lb Blown 383
Transmission: 700-R4 3,000 stall
Axle/Gears: 3.55 moser 12-bolt
I ha a set of MT Sportsman pros on my 16" GTA rims. They fit nicley, however, I spun them on the rim, blew the tube and got a flat after I launched a few hard launches. I would recomment MT ET streets on 16" GTA rims, w/ screws or w/ no tube. I am also thinking about having the front rims narrowed, but I'm not sure if it's possible. Does anyone know. BTW the GTA rims are 16x8
Justin 87 GTA--organizer: "NY2K" Gathering. Blk/Gld w/Superam, 355cid Trickflows, forged pistons 9.5:1. Auto 2,600 stall, 3.45 9 bolt disc, Best time & mph 13.567 @ 101.900 w/ a poor 60ft. Best mph: 104.3 *This car is 100% NYS emissions legal, w/ all emissions controls!* "If you want to have a fast car, hang out w/ those who do!"
http:// www.community.webtv.net/munks87/JustinsGTApage.com
Engine: 400 & 355
Miles
My warriors are centerline also, That will give you an idea of what they look like. I tkink they are compareable in price to the auto drag's. I have seen a camero with auto drags and it looked good.
Later
John
Later
John
i've got a set of mccreary's(I think they are about a 26x10 dot slick) on some monte carlo rims (15x8) and they work fine. Worked on my friends car at a 12.25. It's a lot cheaper, but it's all about your budget. Drag rims aren't badly priced, but I found a few other go-fast things to buy for that much.
Btw, we didn't use screws or tubes with a 1.70 60'.
And that's a good question, can you have the stock rims narrowed? They'd already be spaced right, and have that sleeper effect.
Scott M.
[This message has been edited by Surreal86z (edited December 21, 2000).]
Scott M.
Engine: 400 & 355
Miles
I got a pic of my warriors if you care to look. http://www.geocities.com/spuds82firebird/Mvc-031s.jpg
John
John
Hey, I'm buying a set of Jeep Cherokee rims.. Dont know the part number
17" Im getting them spaced and im mounting Slicks on them
Spraying them gold... Only a 3rd Gen or Camaro/Enthusiast will be able to set them apart from the WS6 rims on my GTa Trying to preserve the stock appearance
1 Post
Car: Junk
Engine: Junk with nitrous
Transmission: Junk with gears
My friend vadim (aka No Rice) runs a pair of Hoosier 9inch slicks on stock firebird 15X7 rims and although the bow out a little bit on the rim, they work just fine, he goes street racing on them every weekend so it must work pretty good Don't know about skinnies, but he has 205/50's up front on the same rims and they seem to make a pretty good combo with the big slicks.
Nice car: 1988 Formula 355, mildly ported/polished Vortec heads, RPM intake, Comp Cams Extreme 268 cam, 650 Holley double pumper, 5-speed/3.73 Richmond gears, and N02 on the way
Old 1/4mile: 13.5@105mph
Evil Car: 78 Pontiac Grand Prix, 500inch caddy motor, edlebrock intake,HP Holley 750 DP race prepped carb, B@M TH350 tranny, 16inch Iroc-Z rims, blacked out chrome, soon to run 10's...
There's no replacement for displacement!
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
Thanks for the picture John. I think I am still partial to the auto drags though.
Thanks for all the other responses guy. Doesn't sound like there is much of a choice for rim width.
Miles
88 427 Camaro
www.koolmeister.com
Miles
88 427 Camaro
www.koolmeister.com
I've been able to fit MT ET streets 12.5x15x28 on my 7 inch wide rims...
Now, thats not what is best cause its kinna bubbly, has you can see on the pic.
But they do make drag radials for ANY rim out there...
LT1Formula
11-16-2015 01:13 PM
kah992
08-19-2015 02:55 PM
