compression ratio of stock 350. 55-86 - Third Generation F-Body Message Boards
Thread Tools Search this Thread
Old 01-29-2001, 09:04 PM   #1
Car: 96 Formula/82 T/A
Engine: LT1/350 TPI
Transmission: T56/TH350
ok. i bought a 350 rebuilt crate motor from kragens auto parts. i think the compression is 8.5:1 , but i want to get new heads and i want to go to 9.3-5:1 at least. but i dont want to go over 10:1. what cc chambers should i get with my heads. im thinking of getting S/R torqer. they have 67cc and 76cc.
thanks.
oh. and i want to get edelbrock proformer plus cam (part number EDE-2102). right now i have 1.6 proform rollor rockers. but edelbrock says to keep stock ratio (witch is 1.5) will it still work with 1.6. thanks
the reason im doing all this is because i crushed a lifter. so i might as well when the intake is off.
RED82TA5.7L
1982 Pontiac Trans Am
Cross-Fire Injected 5.7l V8
New TH350 Raptor with a shift-kit, 2600 stall torque converter, Eldebrock TES Headers, 3" Hooker Cat-Back.
Mods: 1.6 Proform Roller Rockers, electric fan, Corvette 5.7L computer chip, K&Ns.
Audio: JVC Kameleon CD deck, Jenson 4x6 front, Eclipes 6x9 rear, 2 10" mTx T4000 powered by a mTx 200watt amp.
Black Powder Coated 1990 16x8 Formula Wheels with 245/50/ZR16 Perelli P7000.
For Pictures go to
http://members.theglobe.com/RED82TA57L/mycar/
A cool Trans Am site with Message Boards http://www.transamgta.com
RED82TA5.7L is offline vBGarage Page   Reply With Quote
Old 01-30-2001, 11:35 AM   #2
Engine: LT1/350 TPI
ttt, PLEASE HELP
RED82TA5.7L
For Pictures go to
Old 01-30-2001, 12:37 PM   #3
Red,
You will not get a big response since the question you ask requires clarvoiancy on our part. But....I'll try to help.
Assuming you have a .030 overbore on your block, you have a swept cylinder volume of 727.41 cc's.
Presuming your block was not decked any or very little, you have a deck height of .020.
This is about 4.4 cc's.
Presuming you will use a .041 compressed thickness head gasket, this will be 9.1 cc's.
Presuming you have a cheapo cast piston, it's probably got an 11cc dish and a ring land volume of 1.5 cc's.
Using a total volume of 753.41 cc's plus a 58cc head, we get 753.41 plus 58 divided by
58 + 4.4 + 9.1 + 11 + 1.5
Equals 811.41 divided by 84 = 9.66 to 1
Perfecto Rocky, but you'd best find out for sure if those pistons are really the 11cc dish type. A flatop will make much higher compression. Also, that .020 deck height is a guess. It could be anywhere from .040 to zero.
There are far too many presumptions in here for me to say "go for it" right now.
The S/R torquers are "stock replacements". You may want to shop for a set of Corvette 58cc heads instead, since those S/R's need to be fully ported and polished before you see a big power increase.
Good luck.
BOR
[This message has been edited by Box of Rocks (edited January 30, 2001).]
Box of Rocks is offline vBGarage Page   Reply With Quote
Old 01-30-2001, 01:54 PM   #4
Engine: LT1/350 TPI
thanks
RED82TA5.7L
For Pictures go to
Thread Thread Starter Forum Replies Last Post
is this too much cam for me??? beastin91rs Tech / General Engine 18 10-09-2015 08:38 AM
[OH] 28 spline axles, stock Genopsyde Engine/Drivetrain/Suspension Parts for Sale 3 10-07-2015 09:35 PM
Easiest, cheapest tpi swap for 88 truck Keith5 DFI and ECM 2 08-27-2015 05:37 PM
'90 Firebird T/A no Speedo after replacing ECM marcusaw DFI and ECM 4 08-10-2015 09:13 AM
Blue valve covers? mustangman65_79 Tech / General Engine 4 08-08-2015 02:18 AM
Go Back   Third Generation F-Body Message Boards >
Tags
1993, 350, 58cc, 87, compression, crossfire, engine, heads, karmeleon, piston, ratio, sbc, stock, tpi, volume
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
All content copyright 1997 - 2014 ThirdGen.org. All rights reserved. No part of this website may be reproduced without the expressed, documented, and written consent of ThirdGen.org's Administrators.
