What thread sealer to use on head bolts????
Old 03-08-2004, 12:31 AM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
At the auto parts store there is like 15 different types and brands of tread sealer which is the best for use on head bolts?
Old 03-08-2004, 01:17 AM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
don't.
just make sure your not re-using your old "torque-till-yeild" bolts. buy new ones.
and torque the new ones down to the proper spec.
Old 03-08-2004, 01:38 AM
Snake Oiler's Avatar
Car: 84 Z/97 Tacoma 4X4
Engine: 350 H.O Crate,slp 1 3/4,3"catback,Edelelbrock 1406,Edelbrock perfrormer Endurashine
PERMATEX #2b
Old 03-08-2004, 04:22 AM
ede
ede's Avatar
anything non hardening should work. liquid teflon seems to be the prefered sealer any more. i use permatex PST.
Old 03-08-2004, 09:21 AM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Why can't i use the stock bolts??? They are new off a GM create engine just changing the heads
Old 03-08-2004, 09:44 AM
ede
ede's Avatar
SBC doesn't use TTY bolts. you can tell a TTY bolt by a torque spec like 45 ft/lbs and a 1/4 turn or 45 ft/lbs and 90*turn
Old 03-08-2004, 10:03 AM
GASGZLR's Avatar
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
I use ARP thread sealer that I got from Jegs. It's a 7 oz tube and it works great.
Old 03-08-2004, 12:54 PM
Slow89Iroc-Z's Avatar
Car: 1989 Iroc-Z
Engine: 350ci SBC
Permatex #3H or #3D
Old 03-08-2004, 01:44 PM
Nebu's Avatar
Car: 91' Camaro
Engine: Carbed 305
Transmission: 5-Speed Manual
does permatex ultra blue work too?
nebu.
Old 03-08-2004, 01:50 PM
ede
ede's Avatar
non hardening, not rtv or anything else that sets up and gets hard
Old 03-08-2004, 02:02 PM
Car: 1989 Iroc-Z
Engine: 350ci SBC
Permatex® Aviation Form-A-Gasket® No. 3 Sealant
Nonhardening liquid gasket sealant/dressing/coating is a thin, brushable dressing or sealer for close-fitting parts. Suitable for continuous temperatures to 400°F (204°C). Resistant to antifreeze, aviation fuels, high-detergent oils and lubricants. Conforms to MIL-S-45180 D.
Suggested Applications:
Gasket coating or sealing close-fitting machined parts.
P/N Container Size Pack Item #
3D 16 oz. bottle 12 80017
3H 4 oz. bottle 12 80019
Old 03-08-2004, 02:29 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
this is what i bought from the store... http://www.permatex.com/products/pro...&item_no=59214
Will that work??
I can't find anything from permatex that says 3D or 3H in the store or on there web site.
Old 03-08-2004, 02:37 PM
Car: 1989 Iroc-Z
Engine: 350ci SBC
That will be ok for head bolts. However I have found that gas breaks that sealant down so I wouldnt use it to seal rocker studs or intake bolts....
http://www.permatex.com/products/ind...%203%20Sealant
Old 03-08-2004, 02:47 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
So is 3D and 3H the same thing just differnt size bottles?
Old 03-08-2004, 03:06 PM
Car: 1989 Iroc-Z
Engine: 350ci SBC
yea
Old 03-10-2004, 12:04 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
i use plumbers pipe thread dope in can with cap brush, ive never had any problem with using such for ten years now
evilstuie
01-09-2020 08:29 PM
ZMWojnar
Brakes
05-12-2019 10:43 PM
355tpipickup
08-25-2015 12:54 AM
86White_T/A305
08-17-2015 12:16 AM
Quick Reply: What thread sealer to use on head bolts????
