Need a place to bring my car
Old 03-07-2001, 12:24 AM
89ringer's Avatar
I can understand if this gets locked but I cannot think of anywhere else to ask this.
With that said. I go to school in Rochester NY, I just recently brought my car up here. Was wondering if someone could reccommend me a place to bring it to, for general repairs, tune ups and things. Its too cold this time of the year and i have no garage to do anything in =[ .
Old 03-07-2001, 10:51 AM
Nightcruzer's Avatar
Car: Trans Am
Based on extensive research I have done on this subject, picking a mechanic that won't rape you is tough. But here is what I learned. First, ask around. See if people recommend or tell you to avoid anyone in particular. When you get a couple of names, check to see the following:
1) Are they AAA certified.
2) ASA certified
3) ASE certifeid
4) Have a clean record with the better business bureau.
All this info for 1-4 can be found on the respective websites.
I doubt you will find one that has all 4, I live in Brooklyn, NY where there are thousands of mechanic shops, and none fit all 4 criteria. Only two meet 3 of the 4.
Finally, Be cafeful about the ASE certification. There are over 40 catergories to be certified in. Being an ASE certified mechanic for air conditioner recycling doesn't mean he/she knows about transmissions. Ask what they are certified in.
Hope this helps.
Old 03-07-2001, 11:02 AM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
You may want to ask this at www.nethirdgen.org as alot of the people that post there are from around your area. You may get a better response.
1985 ASCD Ram Air Trans Am
http://www.execpc.com/~karpsta/home.html
to find out more
-=ICON Motorsports=-
Old 03-07-2001, 08:09 PM
GearHead1973's Avatar
Being ASE certified dosent give a gurantee that someone knows what they are doing just that they are good at taking tests. I think seeing these signs out front a garage gives a person a false sense of security. Ask around for a good recommendation.
Spyder_TheGamer
12-25-2015 05:07 PM
thefirebirdm@n
South Central Region
09-14-2015 01:45 PM
mustangman65_79
09-01-2015 03:51 PM
Brcharrelson
08-26-2015 07:47 PM
Quick Reply: Need a place to bring my car
