blue smoke at startup... oil drane holes blocked?? - Third Generation F-Body Message Boards
Thread Tools Search this Thread
Old 08-30-2004, 08:53 AM   #1
Liquid_Metal's Avatar
Car: Red '89 GTA
Engine: TPI LB9
I've read that when there's blue smoke at startup it's either bad valveseals or valveguides or then it could be clogged oil drain holes. My brother who's a mechanic told me that if there's carbon sludge blocking the holes you would probably know by checking through the oil refill hole if it is clean inside.... did that and it looked clean.
But I'm wondering if they still could be blocked??? I mean I didn't really see the holes. Where are they locatad exactly? A pic with the valve cover off would help
Thanx in advance!
Liquid_Metal is offline vBGarage Page   Reply With Quote
Old 08-30-2004, 10:12 AM   #2
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
Sorry, I don't have a picture.
At each end of the cylinder heads there are holes to allow oil to drain back to the oil pan. One hole at each end, so there are a total of four.
In addition, there are other ways for the oil to drain back. There are other holes and slots - like where the pushrods go through the head - that also can contribute to oil drain back.
The holes vary in size depending on the particular head but generally are about the size of a nickel or a quarter.
The oil the gets pumped up the pushrods to oil the rockers and cool the springs then drains toward the front and rear of the heads, then down through those coin sized holes, into the lifter valley (where the lifters) are and then through more holes until it returns to the oil pan.
Unless your engine has very, very high mileage and received ****-poor maintenance, I seriously doubt the drain back holes are blocked. You'd have to REALLY neglect oil change intervals to cause enough crud to build up to block the drain back holes.
Blue smoke at start up is most often caused by bad/worn valve stem seals.
Jake
JakeJr is offline vBGarage Page   Reply With Quote
Old 08-30-2004, 12:14 PM   #3
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Vortec drain back holes.
But as stated, usually a smokey startup is bad valve stem seals.
Stekman is offline vBGarage Page   Reply With Quote
Old 08-30-2004, 02:56 PM   #4
The MAIN drainback holes for a SBC cylinder head are down in the depressions on either end of the head under the valve cover. If the drainback holes were plugged you might have an oil-puff-on-startup problem, however, worn out valve guide seals are far more likely. Might want to plan on replacing the seals and then just clean out the drain-back holes while you've got it apart, if they need it. That way you've got it covered from both directions.
Damon is offline vBGarage Page   Reply With Quote
Old 09-01-2004, 12:14 PM   #5
Car: Red '89 GTA
Engine: TPI LB9
Yeah, you're probably right. The engine has been average or well maintained, so I'm sure it's valveseals.
Thanx alot guys!!!!
Thread Thread Starter Forum Replies Last Post
Missing diverter valve? lakeffect2 Cooling 11 08-23-2015 09:44 AM
[VA] Oil Pan Gasket and 2 K&N Oil Filters Navy8125 Engine/Drivetrain/Suspension Parts for Sale 4 08-21-2015 10:32 AM
Only half of lifters getting oil. help. Cameeeero Tech / General Engine 3 08-20-2015 04:06 AM
Project Torched 2.0? 86White_T/A305 LTX and LSX 0 08-17-2015 01:16 AM
Mutliple questions bamaboy0323 Tech / General Engine 2 08-15-2015 08:20 AM
Go Back   Third Generation F-Body Message Boards >
Tags
back, cleaning, clogged, cylinder, drain, drainback, drains, engine, head, heads, hole, holes, oil, plugged, sbc, smoke
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
All content copyright 1997 - 2014 ThirdGen.org. All rights reserved. No part of this website may be reproduced without the expressed, documented, and written consent of ThirdGen.org's Administrators.
