4" crank
Old 08-31-2004, 06:50 PM
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
Axle/Gears: 12 bolt 3.42
4" crank
Will a 4" crank fit in a 305?
Old 08-31-2004, 08:42 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
If by 4" you mean the stroke, no, at least not logically.
2" (for the distance from the crank centerline to the rod journal) + 6" (connecting rod) + x (piston height) = 9.xxx deck height
Where "x" equals the piston height. You would need about a 1" compression height for a piston. Good like finding that for a good price. Also, the clearancing needed is a bit much.
Why would you even want a 4" stroke in a 305. Cost vs. output, the 305 is CLEARLY lacking versus the 350 block.
Old 08-31-2004, 09:02 PM
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
probaly because its way out of the ordnary and i want my car to have the orignal block it but it would be different. more powerful than a 335 or a 340. just trying to keep the same block. also i have a concerns about california smog and i know there is no law about substution for cubic inches. thanks for your help though.
Old 08-31-2004, 09:05 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
What is the budget for this project.
Keep in mind, pistons alone will be $600+ probably.
Oh yea, unless they check casting numbers and cross reference to the VIN, look at the outside of a 350. Then look at the outside of a 305. There is no difference.
Old 08-31-2004, 09:41 PM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
There are special blocks designed to fit a 4" stroke. They have a raised camshaft for extra clearance and the oil pan rails are located further apart.
I guess some guys have used 4" stroke cranks in factory 350 blocks, but I wouldn't want to try it, cause it would be a very labor intensive project. Same thing for a 305 block.
Old 08-31-2004, 11:49 PM
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
about 3500 and i just want to redo the bottom of the engine cause i already have edelbrock heads,intake,runners,and chip done to the car. but it sounds like it might have too much labor involved even though i pulling the engine myself.
Old 09-01-2004, 04:42 AM
ede
ede's Avatar
you'd be ahead to pull the engine if you're that worried about the numbers matching and buy a 350 block, or even a 400. reguardless it'll take a lot of specalized pieces to make a 4" stroke work in a SBC.
Old 09-01-2004, 11:08 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Does anybody have pics of a 4" crank SBC? How about pics of the clearancing?
Falcon50
08-22-2020 03:26 PM
RS Reaper
10-17-2018 07:52 PM
skinny z
10-05-2015 06:23 PM
anesthes
09-30-2015 07:48 AM
Badass355ciz28
09-28-2015 08:31 PM
Quick Reply: 4" crank
