Help me with head choice for boosted motor.
Old 02-19-2005, 10:53 AM
Dragroc's Avatar
Car: 1989 Camaro IROC-Z28
Engine: D1SC Procharged 350
Transmission: D&D Performance built T-56
Axle/Gears: Moser 12-bolt 3.90
Well, I have decided without much thought that the L98 aluminum heads that I have are not worth putting back on my motor. I still am going to have a 350 ci, but have replaced everything in it except for the crank, which was forged anyways(forged rods/pistons). I am putting a D1SC Procharger on with around 12-15lbs of boost, and I wanted a good flowing set of heads. I have been looking at the AFR 195's, Dart Pro 1's, and Brodix Track 1's. I'm kinda partial to the 195's cause even though it is supercharged, the Darts and Brodix heads have big intake runners, and the lower lift flow numbers are better on the 195's. It also looks like I am going to have to have the heads milled down to 58cc or 64cc at highest because the compression ratio might be too low otherwise. Compression ratio now is 8.71:1 with a 58cc head. Thoughts/suggestions anyone?
Old 02-19-2005, 01:32 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
Depending on how much boost you run the 8.5:1-9.0:1 compression is perfect. I was looking at putting a turbo on the TA and looked at the AFR 210 cc heads. I was going for a below 9:1 compression setup so I could run 12-15 lbs of boost...
Old 02-19-2005, 02:30 PM
Project's Avatar
Car: 85 Camaro Z28
Transmission: 700-R4
AFR 190
Old 02-21-2005, 01:27 PM
Dragroc's Avatar
Just called AFR for thier input, and they suggested the 210's, so they are ordered...7 weeks wait.
Old 02-21-2005, 07:37 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Good choice IMO. For a boosted motor they are what most people suggest...
Old 02-21-2005, 08:11 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Make sure you inspect them well before using also. I found a small disc in my 210s from where they were cutting out the coolant passages. I didn't even notice till I tilted the head to one side getting ready to put it on after it came back from the shop.
Old 02-22-2005, 07:41 AM
Dragroc's Avatar
Thanks for the warning!
Old 02-22-2005, 07:45 AM
/\/3\/\/l8l3's Avatar
speaking from experience your not going to like how the lowend treats you with 210's, i bolted on a friends set of 190's and it was much better bottom end and for daily type driving.
he was also suggested by AFR for 210s on a turbo 383, so we traded straight up, his bottom end was just like mine, while his rpm range over 5000 was really nice...
210s are trash imo
Old 02-22-2005, 08:00 AM
Dragroc's Avatar
Were you running an auto? I have a six speed and 4.10's, so getting up in the rpm band isn't that big of a deal, and this car is definately not a daily driver so...I was mainly worried about the exhaust ports being big enough to get rid of the spent gasses. If all else fails, guess I'll have to go with a smaller gear.
camaro71633
09-01-2015 10:24 AM
BlackphantomZ28
08-22-2015 01:00 PM
86White_T/A305
08-17-2015 12:16 AM
Feffman
Mid-West Region
08-13-2015 07:12 AM
Feffman
08-13-2015 07:11 AM
Quick Reply: Help me with head choice for boosted motor.
