name that connector
name that connector
I just noticed a really oily connector that looks like it has never been plugged into anything. I found it when I took my intake manifold out, it was sitting right behind the AIR pipe that goes around the back of the engine. It looks just like the connector that goes into the TPS but it has only two prongs. It is draped over the back of the block toward the drivers side. What is it?
I didn't know there was a MAT extension, but the wires are orange and brown(maybe black?). It isn't to the egr solenoid. Its pretty dark so I can't see it all that well. Im pretty sure it isn't the VSS for the tranny, I think I saw that it was plugged in last time I was under the car. Wouldn't that cause some problem, anyway? Thanks for the help, hopefully I can find somewhere to plug it in =p
i had a couple of them in my 87 305tpi, they did not goto anything, i was all worried about it and asked a GM tech and he said they were for diagnostics. weather or not they were i was just concerned i forgot to hook something up. but i didnt. they could be for options you dont have in your car, or like the guy told me...diagnostics. as long as you hook up up what you took off you should be fine
http://people.ne.mediaone.net/gdm
87 z28 bowtie aluminum 420small block dry sump crower lt. wt. knife edged crank oliver lt wt rods brodix track 1's super ram intake slp 1 3/4 headers accel dfi art carr 700 r4 3.42 gears ssm sub frame/ladder bars.....other parts on the way ,soon to be finished!! couple more weeks!!!
TMZIrocZ350
10-07-2015 12:09 PM
tmork454
09-29-2015 06:33 PM
