Which Brake Pads are Easy on Rotors ?
Old 08-22-2001, 09:59 AM
GTA88's Avatar
I know that "semi-metallic" pads eat up the rotors pretty quickly. I used to use "organic" Raybestos pads from National Auto, which seem to have disappeared latley, which were great, whatever they were. Lasted a long time and didn't destroy the rotor.
AutoZone says they have something called "carbon-metallic" which they say are easier on the rotor than the "semi-metallic".
What pads are out there that are easy on rotors? And what are these "carbon-metallics" and are they really easy on the rotors ?
88 GTA 5.7 TPI Charcoal Grey Bone Stock except for loose muffler which makes it a bit louder than normal.
Old 08-22-2001, 10:20 AM
Guest
Guest
Posts: n/a
Carbon metallics easier on the rotors than semi metallics? LOL uhhhhhhhh no.
Keep looking around for organics if you want those. I know they are still made by many manufacturers, just have to look around more.
Old 08-22-2001, 10:31 AM
GTA88's Avatar
Madmax,
You're right. I just found some at National Auto, brand is "Satisfied", and they are organic, for $12.99. Cheaper than semi-met, last longer, and better for the rotor.
Vintageracer
01-10-2020 05:33 PM
Eric-86sc
04-03-2016 03:52 PM
LittleFranks
09-17-2015 12:22 PM
g.l.mos
08-22-2015 12:02 AM
kyleb24
08-15-2015 08:24 AM
Quick Reply: Which Brake Pads are Easy on Rotors ?
