Oil Pan guru's Inside please...:)
Old 09-08-2001, 05:43 PM
70Monte355's Avatar
We are putting the oil pan back on my husbands Formy..There are 3 clip thingys that he took off with the oil pan bolts. He doesn't remember and I have no clue of where to put them back.
One looks like it is for the tranny coolant lines, but I don't know where it goes. Also, the other 2 I have no idea what the purpose is or where they go.
Please help..Asap.
Thanks!!
Stella
1987 IROC 305 TPI (Stella's daily)
1990 Formula 350 w/ T-Ram (Kevin's toy)
70 Monte Carlo (Stella's toy)
"You boys come here to race or just kiss? You want to know what I got underneath my hood?"
_ ____ _
Original Member of the Rice Converters Crew
70 Monte Carlo 355
90 Formula 350
80 Chevy Truck
95 Saturn
94 Chevy Conversion Van
Old 09-08-2001, 06:34 PM
poncho9789's Avatar
they go to the oil cooler (the part that was under the oil filter boss).
Old 09-08-2001, 08:41 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Your right about the tranny cooler lines. It should be "forked" w/ two prongs bent back up. It goes on the passenger side towards the front about 4-5 bolts back. Not sure about the others.
FREE CARFAX Record Check
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
Old 09-08-2001, 09:54 PM
70Monte355's Avatar
<font face="Verdana, Arial" size="2">Originally posted by poncho9789:
they go to the oil cooler (the part that was under the oil filter boss). </font>
Can you be a little more specific? It just isn't clicking what I am supposed to do with them or where they hook to. Thanks!
Old 09-08-2001, 10:39 PM
poncho9789's Avatar
there is a piece that goes inbetween the block and the oil filter,that is the oil cooler that cools the oil by passing anti-freeze through the cooler and cools the oil, those hoses hook up to the cooler and I can't remember were they hook into the cooling system at. that is one of the things I will have to figrue out when I go to put my engine back in.
good luck
Hotrodboba400
12-10-2019 07:07 PM
ericjon262
09-11-2015 06:07 PM
carattini
09-10-2015 07:46 AM
dmtz956
LSX and LTX Parts
09-06-2015 04:45 PM
Hotrodboba400
09-02-2015 07:28 PM
Quick Reply: Oil Pan guru's Inside please...:)
