Loud Clicking Sound Upon Acceleration
Car: '01 Z28 , '88 WS6
Engine: LS1 , LB9
Transmission: 4L60E , 700R4
Hey. My 1988 WS6 makes a horrendous clicking sound when I'm accelerating. It doesn't do it with the typical engine rev in park, neutral, or whatever, but only when I'm under light or heavy acceleration. Its a 305TPI with 40k miles on the drivetrain, and Posi Rear. Any ideas? It seems to be coming from the rear, but I resealed the gasket and filled differential fluid. Thanks!
Car: 1998 Volvo S70
Engine: B5254S Engine
Transmission: Automatic
Axle/Gears: It's a volvo?
Yeah I dunno man, I have been having almost the same thing, I hear it from the rear or atleast I think it is, and then I think twice and maybe its up front....
I doubt its an engine ticking, I am prolly going to have to check out my rear, I always thought it was my engine mounts that could be ticking but thats not it for sure...
I'd also like to know what it may be...an old screw perhaps? Sometimes its the simple things.
Engine: LS1 , LB9
Also, BTW, the car has been sitting for 5 years with a few times being driven around. I just greased all the fittings today cuz it was bone dry, but still there is a click. If all else fails, I'll record a video of it.
Yes, it will most likely be something really small.
Car: 1986 Chevy Camaro Z28
Engine: 4BBL 350
Probably a stupid question here:
Is it an exhaust leak? Typically exhaust leaks will be really quiet w/o load, and pronounced when under heavier load (e.g. accelerating)
I had an exhaust like on my Camaro that sounds nearly identicle to that of a valve ticking or something.
Just something to keep in mind.
Car: VIN=85 T/A, CAR=82/3 T/A gfx, go figure. She's a T/A anyway!
Engine: 5.0, Holley 600 cfm 4-barrel
Transmission: THM350 ??
Once you start feeding some torque through the driveline, that can (and does) make the exhaust joints open up if they're not tight enough.
Mark.
Engine: LS1 , LB9
1 Post
Car: '86 Berlinetta
since it's recently added exhaust, just make sure that everything is tight, and if you had anything welded that none of them are weak welds.
Car: 88iroc 89formula 80z28
Engine: 350tpi 305tpi 3504bbl
Transmission: 700r4 t5 th350
have u checked flexplate?They have been known to crack between bolt holes.Had it happen on my 88iroc.It makes aclicking sound only under load
Car: 1988 Pontiac Firebird Formula
Re: Loud Clicking Sound Upon Acceleration
Hate to stir up a really old thread but am having an identical issue and was wondering if there were any answers to this. I just purchased the car and it had been sitting for a year without running went through did all the typical fluid changes tune up and everything exhaust seems tight but there is a slight leak but don't think that's what causeing it.
Engine: 5.7 TPI
Ticking coming from engine? Only during acceleration? All the time? Few more details please.
Engine: 5.7 TPI
Yeah, I would suspect an exhaust leak. Might be visible in the dark..... maybe....
Denricci22
09-18-2015 09:02 AM
