Smog Pump, AIR removal on TPI
Old 08-23-2005, 09:29 PM
sorch60's Avatar
I bought my first TPI car, it's an 88 305. I was considering removing the AIR and smog pump from it but was wondering what if any problems I would have after doing this. I was also going to put in a stage 2 hypertech chip, would this correct any problems that removing the other parts would create. Please only real answers and no crying about emmissions. Thanks a lot.
Adam
Old 08-24-2005, 05:02 AM
ede
ede's Avatar
the real question is what do you think you'll be gaining from doing it?
Old 08-24-2005, 10:12 PM
IrocJT's Avatar
Re: Smog Pump, AIR removal on TPI
Ede - always helps to answer a question with a question...
Sorch- No, the chip will not solve any problems created, the chips are designed to work on an unmodified vehicle (well sort of, they work fine with certain upgrades, but are not intended for a vehicle with emissions and other parts removed).
If you so desire, I would recommend doing it regardless. I will admit that I am not extremely knowledgeable on TPI, but I'm pretty sure that the removal of those parts will not throw any codes or cause any serious issues.
I do have personal experience with hypertech stage II chips however and in my case it definitely made a significant difference.
Later,
Jordan
Old 08-24-2005, 10:22 PM
Supporter/Moderator
ShiftyCapone's Avatar
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Check out the stickies in the exhaust board. Some TPI set-ups are sensitive to AIR removal.
Vintageracer
01-10-2020 05:33 PM
italiano67
12-11-2016 09:21 AM
stalkier
08-13-2015 12:59 PM
Sanjay
08-12-2015 03:41 PM
3rdgenparts
08-08-2015 07:09 PM
Quick Reply: Smog Pump, AIR removal on TPI
