Proj hp numbers w/ 350ci and 336 heads - Third Generation F-Body Message Boards
Thread Tools Search this Thread
Old 08-28-2005, 12:47 AM   #1
Ok, first I would like to say that this is Midnyte 81. Now back on subject.
I have this, and this is what I'm finally sticking with:
-mildly ported and polished 3986336 x heads 76cc
-1.5 roller tip rockers (Comp Cams) and hardened pushrods (Federal Mogul)
-Assembled 4-bolt main 350 bored 0.060 w/ stock rods
-Old Style Lunati flat top cast pistons 9.5 CR on 76cc head
-Comp Cams XE268 cam and lifters with 477/480 lift
-Holley 750 DP carb, z-28 aluminum manifold, and 110 GPH fuel pump
-MSD 6AL ignition
*Take note that this in no way will be a race engine. This will not see a day above 6000rpm*
Now, can someone put this on engine dyno and help me out with an estimated hp number on this? In the very near future, I'll get 2.02/1.60 valves on the heads and get a 3-angle valve job for $200.00, but I just got back home from a long deployment and don't really feel like doing it at the moment. Also, this will be going into an 84 z28.
Any help is appreciated!
midnyteeight1 is offline vBGarage Page   Reply With Quote
Old 08-28-2005, 02:52 AM   #2
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Probably around 350 hp. What about the exhaust?
ME Leigh is offline vBGarage Page   Reply With Quote
Old 08-28-2005, 04:32 AM   #3
I'll be using 1 5/8 hooker comp headers and the infamous y-pipe that nobody seems to carry. I'm going with this setup because it cost me only 200 dollars to clean the heads, buy the gaskets, and check the pistons. (Engine was in a flood) I already have Flowmaster 80 series muffler.
Old 08-28-2005, 02:11 PM   #4
Also, is this 350 at the flywheel? I'm looking at a Car Craft article with home ported 993 heads and the same mods I have making 421 hp and 438 ft/lbs of tq. I know it sounds far fetched, but If thet "say" they made that much, I would definately make more with ported and port matched intake runners, bowl blending, and polished exhaust ports. What I really need to know is: What was the stock intake runner and exhaust port volume? That way, I know the increase from the flowbench test. remember that these are the 336 "x" heads that are supposed to have the larger intake port. The last thing I want is an approx hp/tq numbers from info above. I appreciate the help!
Old 08-28-2005, 09:06 PM   #5
I had 993 heads but had to get rid of them. I know there are better stock heads out there, but I'm not looking for one. I already had the 336x's from years ago (Now I sound like I'm old) and I'm just trying to get the old Z28 some pep in her step.
Proj hp numbers w/ 350ci and 336 heads-picture054.jpg
Old 08-28-2005, 11:11 PM   #6
Car: 82 Z28
Transmission: TH350
So did you have them flowed? Port volume cannot be correlated or extropolated into port flow. Porting and polishing can actually make flow worse if done incorrectly.
Old 08-29-2005, 01:06 AM   #7
I should say then I have removed those gross and obvious casting flaws and port matched the intake manifold and heads. The intake and exhaust are bowl blended and the exhaust ports are polished. You would never think cast iron would shine like that. I'm not hogging out the ports and they have maintained integrity. The exhaust port is already the size of the headers and gasket ( 1-5/8 in), so there was no need to enlarge there. I also smoothed out the short side radius. I know I could have gone with the XE 274 cam, but it seemed like too much cam for pure street. Besides, I didn't want to get into that "Gray" area where you would need screw-in studs.
Old 08-29-2005, 11:05 PM   #8
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
If you want to stay out of that "gray" area, drill and pin the studs. thats all that is required.
F-BIRD'88 is offline vBGarage Page   Reply With Quote
Old 08-30-2005, 01:46 AM   #9
I didn't want to get the screw-in studs at the time because I'm getting robbed by the machine shops down here. 200 for it, not including the studs.
Thread Thread Starter Forum Replies Last Post
October 2015 COTM **WINNER** Linson Auto Detailing and Appearance 19 12-04-2015 02:45 PM
[PA] 1992 Z28 Camaro 25th Anniversary SOLD 1992Z28! Camaros for Sale 3 11-19-2015 08:33 AM
HELP 350 HEAD GASKET Jonas Earl Engine Swap 8 09-27-2015 08:39 AM
250-350 john204481 Engine Swap 0 09-07-2015 04:22 PM
[IA] SBC 383 (Short Block and Long block Pricing) gixxer92 Engine/Drivetrain/Suspension Parts for Sale 5 09-01-2015 05:32 PM
Go Back   Third Generation F-Body Message Boards >
Tags
336, 336x, 350ci, 3986336, 3986336x, 76cc, bench, cylinder, engine, flow, head, heads, numbers, sbc, sleeves
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
All content copyright 1997 - 2014 ThirdGen.org. All rights reserved. No part of this website may be reproduced without the expressed, documented, and written consent of ThirdGen.org's Administrators.
