dress up (bling)
1 Post
Car: 89 iroc
Engine: 355 TPI FINALLY
Transmission: 700r4/ SHIFT KIT
dress up (bling)
need some help, do I need a special timing cover for a stock 305 tbi, just looking at chroming a lot of items....not into doing any internal work
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You don't need a special one per se but you need to make sure you get one that has the right timing tab provisions on it. I would be leery of aftermarket chrome covers since I have never heard of one not leaking.
1 Post
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Chrome usually looks cheesy (just my opinion though) on a 3rdgen... cast aluminum looks much better, especially for the intake, valve covers, and timing cover. Cast aluminum almost always seals better too when it comes to parts like valve covers and timing covers.
Car: 83 Berlinetta
Engine: 355
Transmission: TH350
Don't buy the cheap stuff. I bought a cheap set of valve covers and timing cover, and I have an oil slick under my hood from the timing cover leaking and getting on the damper and slinging it all over.
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
I'm kinda with the crowd,I don't dig the chrome a bunch.But if it's what you want,any chrome cover for an early smallblock will work,and I'd recommend cleaning up your stock timing tag,you know it's right.
Just a little sealing tip,it helps on chrome to sandblast all the sealing surfaces to help seal the gaskets.I know it sounds stupid,but it truly works.
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Jims83TA
02-25-2001 02:35 PM
