91-92 dashboard
91-92 dashboard
I'm not really that sure where this belongs. That said...
How difficult is it to put a 91-92 style dashboard/instrument panel into an 89 Iroc? I know there's a few obvious differences, like the shape of the panel and the arrangment of the gauges. But other than that, what's different? Does it use the same mounting spots or would I have to drill my own?
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
89 iroc-z 305 tbi
1 Post
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
hey i was looking into that swap myself for my 88' IROC. I love those backlit yellow instrument clusters. they are much easier to see at night and look cool. i'm not to sure but i think that those speedos use a electronic type.
86',88',89' IROC-Z, 350 TPI, 700-R4
94' Formula, LT1, 6spd
[This message has been edited by mystikkal_69 (edited November 05, 2001).]
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
Trying to swap the instrument cluster in to the old dash is a pain in the *** . It's doable, but requires a ton of work.
Swapping the whole dash is a better solution. It's not that hard.
In either case, you will have to do a lot of rewiring on the instrument cluster plugs. Only ONE pin is in the same place between the earlier style and later style clusters, and it is a ground .
Oh and yes, the speedometers are electronic. That is why I'm swapping--need something that will work with the T56.
"Beware he who would deny you access to information, for in his heart, he dreams himself your master"
'84 Black Camaro Sport Coupe ZZ4 350 M6 -- '84 Olds Cutlass Supreme 231 A3
'91 Medium Blue Metallic Z28 400 A4 -- '99 Navy Blue Metallic Firehawk #120 346 M6
gta892000
09-16-2015 12:37 AM
