327 heads on a 305??
Old 12-08-2001, 12:16 PM
Dans91's Avatar
Car: 91 RS
I bought a motor with a set of 327 heads on it, so i took them off and got them ported and polished. I was going to use them on the origianl block but with these damn smog laws i cannot put the block into my car. My question is, will the 327 heads that have been ported and polished be good on a 305 TBI block??? Thank you for any feedback, it will be greatly apreciated..
Old 12-08-2001, 12:27 PM
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
Well, I know the 327 had the same bore as a 350 (4.00"), and that the 305 has a smaller bore (3.??). You will probably lose compression unless the 327 heads had a VERY small chamber volume. I am by far an expert at engine building, but I would not put those heads on your 305. If the 327 heads came of a 327, find some way to put that engine in your car and still keep your emissions equip. You will probably have to get a bigger TBI unit to feed the High reving 327 if you hav to stick with TBI. After that, just burn a chip (see the DIY-EFI board) so you can stay emissions friendly.
Wait for a second opinion before you make a decision, though.
[This message has been edited by Scott_92RS (edited December 08, 2001).]
Old 12-08-2001, 12:48 PM
Bort62's Avatar
Put the 327 Headed block into te car, There is no Way anyone can tell its not the orignal block.
Anyways, Swapping the 327 heads onto the 305 is against smog laws in the first palce.
85 2.8L Blazer - Soon to to Beater car.
85 Sport Coupe LG4 - Daily Driver 14.55 @ 98.6 (faster than Ed)
Reader's ride -> My Ride
"Faster than Most, Slower than Less"
Old 12-08-2001, 01:03 PM
Dans91's Avatar
Car: 91 RS
Ok the 327 Heads are currently on my 355 project, scheduled to go in mid next year. It came out of a 69 stingray, i was told that this block could not smog because it does not have a knock sensor, so there for my sevice light is going to be on, is there any way that i could bypass that so that the SES light is not on??
Old 12-08-2001, 01:48 PM
irocbsa's Avatar
If you're going to use the TBI then you need that knock sensor.
bsa
Old 12-08-2001, 02:13 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
So what heads are they actually? There are quite a few vastly different castings that were used on 327s over the years.
The knock sensor screws into the right-hand coolant drain plug hole, which all SBCs since they came out in 1955 have. That is not an issue.
ICON Motorsports
[This message has been edited by RB83L69 (edited December 08, 2001).]
Old 12-08-2001, 05:07 PM
ede
ede's Avatar
biggest problem i could see is the ends of the heads not tapped for acessories.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old 12-08-2001, 05:12 PM
toosloz's Avatar
shouldn't they have them ???...isn't a 69' motor a long water pump?
Old 12-08-2001, 06:52 PM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
SBC heads started getting accessory holes on the ends in 1968. The exact location has changed over the years, but you should be able to get most things to mount with some minor work.
Put the whole 327 longblock into your car. Attach the stuff the original engine had on it, you'll be good to go (assuming the cam isn't too wild).
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4, 2300 stall TC. Ported World 305 heads, Crane PowerMax 2050 cam. ZZ3/4 intake, oil pump, pan & baffle. Accel HEI SuperCoil & module. Hooker 2055 headers, 3" Catco cat & 3" catback w/dual-opposite Flowmaster 80. 2.93 limited slip. Spohn SFCs waiting to be installed. AMSOIL syn lubes bumper-to-bumper. Daily year-round driver. Best ET, speed TBD...
57 Bel Air, my 1st car. '66 396, 9.7:1 forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 700 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Jake_92RS
01-28-2020 10:37 PM
gta90
09-15-2015 04:00 PM
Mickeyruder
09-02-2015 02:45 PM
theurge
08-21-2015 12:46 PM
Quick Reply: 327 heads on a 305??
