Recharging problem
Old 04-07-2006, 09:09 PM
CamaRod's Avatar
Car: 91 Camaro RS
Engine: 305 TBI, (right now)
Recharging problem
So my alternator unexpectadly burned out about a month ago, so i chech the battery and it was good it is less than a year old, and so i figured, oh well its a bad alternator. I changed the alternator.
So yesterday i started to notice the volts gage droping and today the battery is dead again, because the alternator didnt charge it back up. And im guessing the alternator is burned up again
What could be causing this
Where should i start to look?
Thanks for any help you all can give me
-Dave
Old 04-08-2006, 10:01 AM
CamaRod's Avatar
Car: 91 Camaro RS
bump for help
Old 04-08-2006, 03:30 PM
BlkBird408's Avatar
Car: 89 Firebird
Engine: 408
Axle/Gears: 12 bolt/4.11
How did you check the battery?? I would have it put on a machine and tested to be sure its good. First I would check the battery cables to be sure they are not corroded, loose or shorting out anywhere. Make sure the alternator belt is tight enough. If those look good then you might have an electrical short somewhere thats draining your charge.
Old 04-08-2006, 03:35 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Like was said - check the battery on a machine that puts load to it - Adavance/Autozone do it for free. Same on the alternator, they'll check it for free. If both good, then something draining battery.
Where in NC are you?
Old 04-08-2006, 03:45 PM
nedoss's Avatar
Car: 1986 Camaro
Engine: 355 HSR
Transmission: TH-700R4
Axle/Gears: 10 bolt 4:11 posi
I agree with camaronewbie if your alternator unexpectedly burned up and it literally "BURNED UP" then I would check for a short. When I worked parts at NAPA here in Texas I had a guy go through about 3 or 4 alternators in about 2 days, when he finally brought the truck up to me I found one of his alternator leads had burned on the exhaust header and was shorting out his charging system. Just something to consider, I would definitely get a parts store to "load test" your battery.
Old 04-08-2006, 05:23 PM
CamaRod's Avatar
Car: 91 Camaro RS
ok so i got the battery checked and it was good, then i was talking to the parts dude, and he is a third gen guy. So he was helpin me out. I went up there and he checked the alternator, and its not putinig out any charge. So he told me to check the fusable links, and i did, they were good. Then he told me to run a jumper from the hot side of the alternator to the batery and i did, and it started to recharge. So it must be some kind of problem in the harness. So now he told me to to check start the car and take off the negative battery lead, and im gonna do that and see what happens
If that guy post here, i really appriciate the help
I'm in raleigh right near NCSU
-Dave
Old 04-08-2006, 07:04 PM
CamaRod's Avatar
Car: 91 Camaro RS
ok so here is what happen
after i cranked the car and it started, and i pull the negative cable the thing cut off. So the alternator wasnt putting enough juice out
After talking to the thirdgen parts dude, he said that the alternator might have burned out if I had changed it when the battery was low (he seaid below 9volts)
Which brings me back to when i had changed my alternator about a month or so ago. I had driven the car about 3 hours (150 miles) and the old alternator burned up, and i charged the battery so i could make it back to my tools, another 3 hours drive. so then i have little more than 8 volts. and i changed my alternator
So i went ahead and pulled the alternator out, and took it up the parts place and had it checked. The Diodes were burned up. So i got a new alternator, and I charged the battery, and cranked it up, and took it up to the parts place, and had them check the output and everything again, and it was good
so let this be a lesson, When you replace your Alternator, ALWAYS MAKE SURE YOUR BATTERY IS CHARGED FULLY!
im an idiot
oh well at least i dont have to fix the wiring harness
Old 04-08-2006, 09:11 PM
Car: 1992 RS
Engine: Carbed 350
I'm glad you got it solved, but FYI ....
Anytime you disconnect the battery cable while the car is running, the car will die - has nothing to do with alternator making enough juice - has to do with you cutting the circuit. It is true that a car will continue to run with a dead battery, and will also run with a dead alternator (until the battery dies) - but the circuit must remain intact - when the negative battery wire is removed, there is no longer a circuit, and thus car dies.
But at least you got there!
I'm in Cary - If you need help anytime, PM me for a phone number - I'll be glad to come over - and let's get together sometime anyway - I love to see any and all 3rd gens!
Old 04-08-2006, 10:29 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Originally Posted by camaronewbie
...Anytime you disconnect the battery cable while the car is running, the car will die - ...
I must have had a slew of magically empowered cars running on the mystcal pawer of magic hamsters then because I used to do that a ton to older cars and trucks and they rarely died.
On the other hand, it is possible to damage an alternator by pulling the neg cable while running. FYI.
Old 04-08-2006, 10:50 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
[quote=Red Devil] I must have had a slew of magically empowered cars running on the mystcal pawer of magic hamsters then because I used to do that a ton to older cars and trucks and they rarely died. [quote]
My thoughts exactly...
If the alt is pumping out power the thing will continue to run, it should work like this on any non EFI car. Now if it was EFI then you better have a 4 figure balance in your bank account to replace all the elctronics you burnt up!
Old 04-09-2006, 12:39 AM
CamaRod's Avatar
Car: 91 Camaro RS
either way i got it working now.
I dont like nor do i much care for the electrical part of working on cars.
So im back to doing doughnuts in the rain and isnt that all that really matters
pjsparts
09-17-2015 01:28 PM
383cam
09-09-2015 06:01 AM
Formula_88AE
09-03-2015 01:47 PM
andy74
09-03-2015 08:41 AM
greenyone
09-02-2015 03:39 PM
Quick Reply: Recharging problem
