best heads for a '67 327?
Old 10-10-2006, 07:43 AM
pistonpowerdrx7's Avatar
i'm picking up a 1967 327 block with rods/pistons/crank to replace the 305 i have in there now, and i was just wondering what would be the best heads to run on this motor for a nitrous setup? i'd like to keep compression relatively low, plan on hitting it with at least a 150 shot so keep it under say 9.5:1. i'm also trying to do this on a budget, so as much as i'd like to have them i can't really afford any Twisted Wedge heads or anything to that extent. What would be good heads to use on this block?
Old 10-10-2006, 03:52 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
What pistons are in there? flat tops?
What cc head do you want/need, in order to get to 9.5:1?
United Engine and Machine Co.
I'd guess in the range of 64cc, so with that wild guess; 083 heads, some of the old school double humps (since you seem to be able to get a '67 327 motor, might have a source for old school parts), vortec heads, or some ported 416 heads (bigger chambers), would work ok on the cheap.
Old 10-11-2006, 08:39 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Originally Posted by pistonpowerdrx7
i'm picking up a 1967 327 block with rods/pistons/crank to replace the 305 i have in there now, and i was just wondering what would be the best heads to run on this motor for a nitrous setup?...
The camel-hump heads on my T/A came off a '68 327-300. They have 62-63 cc chambers. I think they were like 9-9.5:1 back in the day. I would not recommend them unless this is a "low-buck" build. They lack mounting bosses for front accessories and do not have hardened exhaust seats. I have to run lead-substitute in every tank of gas because the heads were designed for leaded gasoline.
I also owned a '67 327-275. (showing his age) The stock heads on that motor had 1.72" intake valves. Hard to believe they made 275 HP with 'em huh? I can vouch for the stock cast pistons in the 327. I burned one in that engine using regular leaded gasoline. (of course it was being rawhided by a teenager).
So, if you have a '67 327 and you're going to run nitrous, you're going to have to get pistons for it.
If you're going to do that, why don't you build a 327 stroker?
It's called a 350.
Available at any junkyard for $300.
Hotrodboba400
12-10-2019 07:07 PM
92projectcamaro
01-18-2016 08:00 AM
FormulasOnly
09-06-2015 10:42 AM
z28guy134
09-01-2015 11:50 PM
Quick Reply: best heads for a '67 327?
