need pics of smog pump location plz.
Car: 87 Firebird, 90 corvette, 05 F150
Engine: 5.0, 502, 5.4L
Transmission: AUto,Auto,Auto
on 87 firebird with a 305. previous owner removed a/c and smog pump. Thanks - Roger
Car: '89 Trans AM/'88 GTA
Engine: (2) Tuned Port L98's
Depending on the model/year.. It should be
located on the passenger side of the block..
You should have a aluminum accesory bracket
that holds both the smog pump and the a/c..
The smog pump goes on the very bottom bracket.
The diverter valve installs right to the back of the smog pump where you can route for EGR for the exhaust.
I should mention that I had some F-bodys
of earlier models have a different accesory
set-ups .. and I cant remember what the
setup was.
setup was.
on my car i have some brackets on the DS of the car, that i dunno what goes there. i found where the smog pump bolts to, but i dont have any brackets forthe a/c. im not real worried beings its winter time, and the car will be becoming a full out drag car in time. but i need the car to run properly w/o the check engine light, and to pass inspection. where do i bolt the bracket for the smog pumps intake tube at?
Yea, I had a feeling you had the older belt/accessory
set-up. I wish I still had my 1987 LG4 car, It too had the
driverside bracketry, but the car is long gone.
I cant remember for the life of me how the system was
set-up tho.. Hopefully someone will chime in
Good luck
Good luck
