VATS problem?
Old 04-26-2007, 03:38 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
VATS problem?
I go out to crank my car today, and it does NOTHING.
All I get are dash lights and a whirring fan (it comes on when the ignition is on).
No clicks, no starter engaging, I dont hear the fuel pump but I dont know what it sounds like, either.
Any ideas?
Just replaced the starter 2 weeks ago.
Old 04-26-2007, 05:38 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Re: VATS problem?
That is common with a VATS issue. I usually left it sit for an hour and tried again. If it starts, then you are pretty certain that's your culprit, and you'll have to find a way to bypass it. Either the resistor method, or with a special burnt prom. I did neither, converted to carburetor, ditched the computer altogether =D
Old 04-26-2007, 07:48 PM
D BERRY's Avatar
Car: 89 Camaro RS
Engine: LO3
Axle/Gears: 273 pegleg
Re: VATS problem?
I kind of wondered if the vats would be a problem when swaping to a carb, good to know it's not an issue.
Dave B
Old 04-26-2007, 08:03 PM
Car: 1992 Camaro RS
Re: VATS problem?
Well Im building a new motor for mine and it's hopefully gonna be ready to drop in within a couple of months but we'll see. I'm plannig on carbureting it anyway so that's good.
But I thought VATS connected to the fuel pump too?
GeneralIesrussi
Carburetors
01-20-2020 01:06 PM
db057
04-28-2019 07:45 AM
andy74
09-03-2015 08:41 AM
GeneralIesrussi
09-03-2015 03:23 AM
greenyone
09-02-2015 03:39 PM
Quick Reply: VATS problem?
