462624 head casting any good? - Third Generation F-Body Message Boards
Thread Tools Search this Thread
Old 05-05-2007, 05:45 PM   #1
Car: 89 Iroc Z
Engine: Gen 1 350
Axle/Gears: Stock and shitty
are these heads worth a ****? do they flow well i cnat find and flow specs or anything ont hem really i beleice it has 194 150 valves
BadIROCZ is offline vBGarage Page   Reply With Quote
Old 05-05-2007, 09:06 PM   #2
//<86TA>\\'s Avatar
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: 462624 head casting any good?
if im remembering the #'s correctly, 76cc crack prone and crap
//<86TA>\\ is offline vBGarage Page   Reply With Quote
Old 05-06-2007, 10:22 AM   #3
Right; they are among the very worst.
1.94" / 1.50" is the stock valve sizes for the majority of 350 heads. Nothing special about that at all.
They can be made to flow OK, they can even have 2.02" intakes and 1.6" exhausts installed in them. However, one of the things that a flow bench WON'T tell you, is that they'll crack between the valve seats if you enlarge the valves (they're bad enough about that with what comes in them). Furthermore, there's some places that get REAL thin in the exhaust ports, that will also crack if they're ported.
They are trash. Throw them there and get something decent.
sofakingdom is offline vBGarage Page   Reply With Quote
Thread Thread Starter Forum Replies Last Post
Trans am V.S Rx8! TreDeClaw Theoretical and Street Racing 4 12-20-2016 12:04 PM
1992 camaro 305 v8 TBI idles very high and shifts at high idles db057 TBI 11 06-07-2016 09:26 PM
More HP on a budget gta90 TPI 40 09-15-2015 05:00 PM
cam choice for budget 400 camaro71633 Tech / General Engine 39 09-01-2015 11:24 AM
350 (Bored 0.040 Over) Head Gasket Size/Thickness? NinjaNife Tech / General Engine 27 08-23-2015 12:49 PM
Go Back   Third Generation F-Body Message Boards >
Tags
350, 462624, casting, chevy, gm, good, head, heads, number, size, specs, switch, to, valve, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
All content copyright 1997 - 2014 ThirdGen.org. All rights reserved. No part of this website may be reproduced without the expressed, documented, and written consent of ThirdGen.org's Administrators.
