help with heads
Old 06-18-2007, 10:27 AM
the86bluebeast's Avatar
Car: 86 iroc/ 86 K5
Engine: none right now/ gm crate 350
Transmission: t56 on the way/ 700r4
Axle/Gears: 3.08/ 3.42
help with heads
got question about heads. right now i have a 400 sb in my 86 z. i am comming home from iraq here in a few months, and am looking to make some more power. ballpark figure i am looking for is 500 +. with a 400 it shouldn't be to hard or too expensive. basically i would like some opinions on heads or head/cam combos. as far as the biggest bang for the buck. i am not a bracket racer, so bear in mind it is still the weekend toy, just with a little bit bigger *****. thanx guy
Old 06-20-2007, 03:51 PM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
First, thank you for your service in defense of our country.
Now, "too expensive" is a very subjective term. $2000 for a set of bare heads isn't "too expensive" to some people. Is to me, but what's your level of pain?
Vortec-style heads are typically pretty cost efficient for the HP made. A set of large-port Vortec iron heads with 206cc intakes, 2.00/1.55 valves, 65cc chambers, capable of .530" lift will run you about a grand http://www.sdparts.com/product/25534...inderHead.aspx . For about $200, you could get a set of aluminum Fastburns http://www.sdparts.com/product/12464...inderHead.aspx . You'll need a Vortec-type intake manifold like the Performer RPM Vortec.
A Comp XE284 cam should put you in that HP range with either of those heads.
How well is your bottom end built?
Old 06-23-2007, 02:17 AM
Car: 86 iroc/ 86 K5
Re: help with heads
thanx for the input. to get a little more specific. the bottem end.......aahhhhh well right now it is just a stock two bolt main. when i get home i will take it to the machine shop and have them slpay the mains and make it a four bolt, then line hone it. all in all the top end of my budget is some where around 1000-1300 for heads.
Hotrodboba400
12-10-2019 07:07 PM
92projectcamaro
01-18-2016 08:00 AM
FormulasOnly
09-06-2015 10:42 AM
z28guy134
09-01-2015 11:50 PM
Quick Reply: help with heads
