Screeching in Gear
Old 06-18-2007, 01:25 PM
Irocwannabe's Avatar
Car: 90 formula 350
Screeching in Gear
Ok heres the thing when i start the camaro everything sounds fine but i get some lights vibration and when i put it in reverse it makes a loud screeching and if i put it in drive it becomes a low random squeak its not the pulleys or belt and i checked the stall converter and one bolt was a little loose but not too bad to where i can turn it by hand. you guys have any idea what it could be????
Old 06-18-2007, 08:12 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Re: Screeching in Gear
Originally Posted by Irocwannabe
...you guys have any idea what it could be????
Can you post an audio? Is the loud screech in reverse a constant screech or a pulsating "scree-scree-scree-scree"?
I would suggest retorqueing the bell housing bolts, especially the upper ones.
gta892000
08-11-2019 11:16 AM
db057
04-28-2019 07:45 AM
88rscamar0
09-23-2015 09:08 PM
Stroopwafel
09-11-2015 06:38 AM
UltRoadWarrior9
09-02-2015 08:24 PM
Quick Reply: Screeching in Gear
