head numbers - Third Generation F-Body Message Boards
head numbers
Thread Tools Search this Thread
Old 12-26-2007, 09:40 PM   #1
89_ho_rs's Avatar
Car: 1989 RS Camaro
Engine: 350 Carb(soon a 400)
Transmission: 5-Speed/th350
Axle/Gears: 10 bolt 3.73
head numbers
i found these heads the vavles look unusually large. i have checked online at the casting numbers but cannot find anything on them i was hoping that someone could let me know about these heads.
the numbers are
3888338 on both heads
89_ho_rs is offline vBGarage Page   Reply With Quote
Old 12-26-2007, 10:04 PM   #2
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Re: head numbers
take a closer look at the casting number. more than likely its 3986336
early 70's 76cc smogger. Was used on 1971 1972 350 LT1 Z/28 (330hp and 255net hp) so could have 2.02 x 1.60" valves with guide plates.
One of the better large chambered smoggers. Not too bad with full on porting.
Kind of old stuff. Not worth paying $$$s for. Lots of better heads today to choose from.
Not bad (with lots of porting) when building a low compression supercharged 350 on a strict budget.
F-BIRD'88 is offline vBGarage Page   Reply With Quote
Old 12-26-2007, 11:01 PM   #3
89_ho_rs's Avatar
Car: 1989 RS Camaro
Re: head numbers
i will take a closer look.
i am building a 400 with je pistons the site said that the pistons are 11:1 with 76cc heads. so i am ok with bigger chambers.
so i got the heads for free are they worth putting the money into the porting or is it better just to get a different set of heads to start with?
Old 12-27-2007, 10:17 AM   #4
81caballero's Avatar
Re: head numbers
the early 70's SBC heads are ok....they have hardened exhaust seats for unleaded gas. BUT, they have very small intake runners by todays standards. if you are going to port these by yourself then go, but if your taking these to a shop to open up and flow, then dont waste your money, grab a set of aftermarkets, because professional porting isnt cheap, and these old iron heads only go so far. Up here in canada we have 94 octane gas, but i beleive in the US its as high as 91....so for 11:1 compression you are going to need to run a mix of 91 and race gas....probobly 50/50 to obtain a 100 octane so you wont detonate. I would steer towards an all aluminum head, that way you are able to run 1 more compression point compared to iron. so 11:1 will act more like 10:1 with the aluminum head and you would be able to run 91 octane with a bottle of octane boost to help with detonation.
81caballero is offline vBGarage Page   Reply With Quote
Old 12-27-2007, 05:10 PM   #5
89_ho_rs's Avatar
Car: 1989 RS Camaro
Re: head numbers
i did recheck the numbers and i am sure they are 338
Old 12-27-2007, 05:20 PM   #6
Re: head numbers
Probably not.
Here's the numbers close to that.
3986336....71......350..........76cc chamber
3986336X...71......350..........76cc chamber
3986339....71......307/350......74cc chamber
3986339X...71......307/350......74cc chamber
3986388....68-76...307/350
Probably one of those.
None of them are particularly good. Some of them are sort of OK for a 350, except for the ones that also came on 307s (2-bbl heads); but even the best stock heads would be thoroughly unsuitable in this day and time for a 400 with dome pistons.
I would not put my money into them.
sofakingdom is offline vBGarage Page   Reply With Quote
Old 12-27-2007, 05:30 PM   #7
89_ho_rs's Avatar
Car: 1989 RS Camaro
Re: head numbers
thank for all of you answers I do appreciate it. I am going with aftermarket heads.
Old 12-27-2007, 05:54 PM   #8
F-BIRD'88's Avatar
Re: head numbers
Do the JE pistons have a dome on the top? If so send them back for ones with a 18-22cc dish (64cc head) or flat top 72-76cc head, or your motor will have excessive compression ratio for pump gas.
Old 12-27-2007, 07:39 PM   #9
skinny z's Avatar
Car: 86 Sport Coupe
Re: head numbers
Check out the MorTec website. Chances are they have your heads listed.
skinny z is offline vBGarage Page   Reply With Quote
Thread Thread Starter Forum Replies Last Post
List of 71 original GM 3rd Gen Part Numbers!! 1992 Trans Am History / Originality 16 04-05-2016 11:20 PM
Is there a Shorter version of SBC plugs for restrictive headers? evilstuie Exhaust 24 02-28-2016 04:33 PM
Carb Raffle Holley, Edelbrock, or Demon BlackphantomZ28 Engine/Drivetrain/Suspension Parts for Sale 0 08-22-2015 02:00 PM
Part number of adjustable low pressure switch dcbsracing007 Cooling 0 08-18-2015 08:24 AM
Procharged 383 TPI Dyno Numbers 85Iroc-Z Power Adders 18 08-13-2015 02:58 AM
Go Back   Third Generation F-Body Message Boards >
Tags
350, 3888338, 3986336, 3986336x, 3986388, 71, casting, chevy, engine, flow, head, heads, number, numbers, sbc
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
All content copyright 1997 - 2014 ThirdGen.org. All rights reserved. No part of this website may be reproduced without the expressed, documented, and written consent of ThirdGen.org's Administrators.
