305 tpi formula does it exist??
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
Re: 305 tpi formula does it exist??
I am not sure if I understand your question but if I do this is my answer. GM made 305 TPI Formula Firebirds so they do exist. My car was a 1988 305 TPI 5-speed car.
Car: currently a 91 G92.
Engine: 305TPI
Transmission: Borg Warner WC 5 speed
Yes, it exists.
I have one. It is a 91 WS6 formula 5 speed.
I know that GM made two TPI 305 engines for the formula. I believe that they also put the 305 TBI in the formula as well.
There were the 305 TPI with automatic, which was rated at 205 hp and 290 ft-lb of torque, and the 305 TPI 5 speed, rated at 230 hp and 300 ft-lb of torque. The 5 speed 305 TPI car came with dual cats and the cam shaft from the L98.
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
My 87 Formula was a TPI 305 5 speed car as well. No dual cats, but it did have the L98 cam. No way for me to know if it was factory or not due to the age/mileage.
my friend was arguing with me i informed him of a 89 formula 305 tpi car and he said there was no such thing so i wanted to prove to him they are out there cause he thinks he is the know it all about firebirds and trans-ams just wanted to prove a point to him
Car: 1983 G20 Chevy
Transmission: 4L60
They ALL had the L98 camshaft from 1990-1992. Every factory 305 prom chip even has the same fuel tables in them.
Exhaust WAS THE DIFFERENCE between the two. The G92 cars got dual cats and more power. The non G92 cars got the same exhaust setup that chokes into a HORRIBLE Y and 2 1/4" pipe that the TBI cars got.
Engine: 305TPI
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
I've got one with a blown 305 sitting in my driveway, I think they were more common than the Formula 350's.
Sanjay
08-12-2015 03:41 PM
