im buying new cylinder heads...
Old 05-15-2008, 03:06 AM
noroxus's Avatar
Car: 1984 Z28
Engine: 360ci SBC
Transmission: WC T5
Axle/Gears: 9 bolt 3.27 Posi
i dont want to spend a terribly high amount for new heads, but i want some aluminum ones to replace these aweful 882s on my 355
i want 64cc ~200cc intake aluminum heads, i was considering either the cheap patriot or procomp heads as i havnt heard anything too bad about either. i would also consider used.
these are more or less temp heads till i build my blown 383 in a year or so.
does anyone have any input or suggestions?
im looking to spend >$1000 shipped
Old 05-15-2008, 04:01 AM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
Re: im buying new cylinder heads...
IMO, if you are just gonna throw em out when the blown 383 is built, dont waste your time or money.. i wouldnt spend another dime on the motor if i had my sights set on another build..
say you get heads for $1000, when you sell them to build your blown 383 you might get $700 back.. you already lost $300 towards your bigger, better heads that your 383 will need..
i would say just suck it up till then..
just my
Old 05-15-2008, 12:33 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F
If you don't need or care about emissions, I'd get a set of Vortec's. They run under $700 for the set assembled. If you want to plan for the 383, you could always get a set of bigger Dart or World heads now, sure they might be a little large for your needs now but would be perfect for the 383 and they run about $1000 or so (Before shipping assembled).
Old 05-15-2008, 01:38 PM
impaled's Avatar
Car: 1985 Camaro and 1996 Mustang GT
Engine: 350 4bbl/281
Transmission: 700R4/4R70W
Axle/Gears: 9" rear/8.8" 4.10
if i were you, i would just save and get the heads for the 383 when you can and not waste a grand on heads you wouldnt use then. even if you go with some huge intake runner heads for now you might lose a little bit down low, but you would still see a decent increase in power (especially over your current heads) for now without wasting a grand.
just make sure the heads combustion chamber volume you get for the blown 383 would be compatible for your piston choice for the blown 383 for the desired compression ratio / boost you want to run on what fuel.
i know alot of people who swear by the dart iron eagle platinum heads, and they are relatively cheaper than the dart pro 1 aluminum for semi similar flow #'s.
db057
04-28-2019 07:45 AM
BumpaD82
02-26-2016 02:57 PM
DiabloWS6
Southern California Area
02-15-2016 02:08 AM
Jlanz55
09-08-2015 11:28 PM
muttracing
Brakes
09-06-2015 08:12 PM
Quick Reply: im buying new cylinder heads...
