so i heard
Old 08-28-2008, 06:24 PM
ksith's Avatar
Car: 87 trans am
Engine: 5.7
Transmission: t-5
Axle/Gears: 9 bolt posi 3:27
so i heard
from someone that because i bored my 350 over 60 and im running headers that it will run a few hundred degrees hotter and that i need to buy a high volume electric waterpump. yes this guy was a sales man at autozone. im pretty sure he's blowing smoke up me rear but what do you all think about this
man i gotta get a new pic of the right bird up there
Old 08-28-2008, 07:39 PM
gurkgurkgurk's Avatar
Car: 86 Camaro iroc-z28
Axle/Gears: 3.42 Posi
Re: so i heard
ask him what high volume waterpump he uses in his ford fiesta
Old 08-28-2008, 07:40 PM
GMLSX's Avatar
Car: 1998 Slow
Engine: Too Small
Re: so i heard
haha, the normal engine runs about 210-220, if it runs a few hundred higher, it would torch the engine. there has to be a thousand blocks that have been bored over, and never had a problem with going a few hundred over haha...
that guys full of S**T and was just trying to make some money off you...
you may look into an electric water pump to take draw off the engine and a better radiator if you plan on getting seroius with the build...
Old 08-28-2008, 09:28 PM
ksith's Avatar
Car: 87 trans am
Engine: 5.7
Transmission: t-5
Re: so i heard
well im gonna have to do something now. i was driving home today. and i had a huge plume of white smoke come out of the exhaust. i pulled over right away and cut the engine off. decided to let it cool down a bit then i try to start it nothing. just the click of the starter but no cranking. then my friend tells me that i have a leak. coolant coming out of the exhaust. bad news i know. so i tryed to turn it by hand to see if it spins. guess what nothing. so i seized it. freshly rebuilt engine and it seized . im going to call the builder tomorroe and see if he will refund my money. the block im afraid is maxed out at a 60 over bore
Old 08-29-2008, 11:50 AM
Re: so i heard
could be hydrolocked, pull out the spark plugs and see if it turns
Old 08-29-2008, 12:25 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Re: so i heard
yes, most likely just hydrolocked from a leaky head gasket...
Old 08-29-2008, 04:14 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: so i heard
and/or one of the bores split.
Old 08-29-2008, 04:51 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
Re: so i heard
haha, dont even talk that way, its just mean!
Old 08-29-2008, 04:56 PM
ksith's Avatar
Car: 87 trans am
Engine: 5.7
Transmission: t-5
Re: so i heard
so if its hydrolocked then its salvageable? im still gonna have to tear down the engine and see if the cylinders are scratched right? and if they are then that motor is trashed right? if thats not the case then darn it i hope its just hydrolocked
Old 08-29-2008, 05:04 PM
irok2fast4u's Avatar
Re: so i heard
if you blew a head gasket and didnt crack anything yes it is totally fixable.However why did it happen,incorrect torque specs,sequence or do the deck surface of block and or heads not get milled, again yes its fixable but you need to know why what happened so you dont tear it down and rebuild it to tear it down and rebuild it again.pulling a motor you just built sukkks but doing it twice sukks alot more.,
Old 08-29-2008, 09:27 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
Re: so i heard
worst case scenario with hydrolock could be a bent rod or crank, but like stated above you need to determine the cause, was it a crappy gasket or a warped head, bad deck job, cracked head/block or maybe a leaking intake gasket....
GeneralIesrussi
Carburetors
01-20-2020 01:06 PM
db057
01-10-2020 08:55 PM
HoosierinWA
Members Camaros
09-29-2015 12:43 PM
mcbitchman
09-29-2015 12:32 AM
SS-EXPRESS
09-28-2015 09:14 AM
Quick Reply: so i heard
