tpi vacuum hose routing
Old 10-22-2008, 09:26 PM
2011 Norwood Gathering
ThirdGen Camaro Rep
89RESTO's Avatar
Car: 1989 IROC
Engine: 5.7
Axle/Gears: 9 bolt 2:77
Hey guys, i need some help, i did a search but i can't find a matching diagram for my car, 1989 5.7 tpi auto trans.I have a bunch of small vacuum hoses and a small black check valve and i'm trying to figure out the routing. one thing that is confusing me is that all of the diagrams i see show two lines comming from the egr solenoid but mine has a two into one connection. The only thing i'm sure of is that one hose goes from the pass. side on the rear of the plenum to the f/p reg.the rest of the connections such as the egr valve, the other small connection on the plenum,the connection underneath the throttle body and the check valve i have no clue. The previous owner tore all this apart so it's possible he has the wrong egr solenoid connection.
Thank's for your help.
Old 10-23-2008, 03:21 PM
BlkBird408's Avatar
Car: 89 Firebird
Engine: 408
Axle/Gears: 12 bolt/4.11
Re: tpi vacuum hose routing
This site has various vaccum diagrams.
http://www.autozone.com/addVehicleId...00c1528008e658
1992 Trans Am
05-10-2023 07:19 PM
lakeffect2
08-23-2015 08:44 AM
mdtoren
08-16-2015 05:45 PM
Sanjay
08-12-2015 03:41 PM
Quick Reply: tpi vacuum hose routing
