Tach/Dwell reading question.
Old 01-14-2009, 08:47 PM
Firebird Mess85's Avatar
Car: 85 Firebird & Grand Prix GXP
Engine: LG4 305 (originally 2.8L V6)
Axle/Gears: 10 bolt 3:43 Open Diff.
Anyone know how I use / where I hook up a tach/dwell meter on the GM remote mount coil I have in the car or if I can even use it on this car?
Old 01-15-2009, 12:25 AM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Do you have a points/condenser distributor?
Old 01-15-2009, 05:58 AM
Damon's Avatar
Re: Tach/Dwell reading question.
Dwell is non-adjustable on an electronic distributor.
If you wanted to check dwell anyway, you attach it to the same place the tach signal wire is hooked up and attach the other lead to a good ground source. On a divorced coil HEI that would be the smaller white wire going to the coil- the plug that goes to the vehicle's wiring harness, not the one that goes to the distributor.
Old 01-15-2009, 06:19 PM
Pretty sure it's not a points distributor. I know that I don't need to check dwell, I was more interested in the tach feature. I don't have a tach on my car at all and want to know where it's idleing. I can't figure out the wire though. The directions for the meter show where to hook up on a bunch of different coil types but not the remote coil I have.
My coil looks like the one below but OEM stock.
Old 01-16-2009, 01:04 AM
five7kid's Avatar
Engine: LS1/LQ4
Tap into the white wire coming off the coil.
Wait, you have an '85? You need to connect the red lead for the dwell/tach to the wire that is not the power to the coil, the other dwell/tach lead to ground.
Old 01-16-2009, 07:28 AM
Damon's Avatar
Yeah, if it's an 85 the coil is mounted on top of the distributor under a dust cover. It's what they used before they went to the divorced coil HEI distributors around 1988.
I didn't catch that the first time through.
You should see the word "TACH" molded into the coil cover on top of the distributor, on the square part that sticks out the driver's side. Plugs go on from underneath that area. You'll see the big pink power wire right next to the TACH terminal. That TACH terminal is where you would hook up a tach signal wire or one of your dwell meter leads.
Old 01-16-2009, 08:07 AM
five7kid's Avatar
Engine: LS1/LQ4
He said he's got an external coil. Must have been swapped in.
Old 01-16-2009, 05:37 PM
Yes, its a divorced setup and the motor is an '87 or later. How am I tapping in to the wire? Its has two plug type connections that connect in the female end of the coil I pictured above.
Old 01-16-2009, 06:50 PM
Damon's Avatar
If your car already has a tach (like 3rd gen Camaors and Firebirds do) then you'll have to piggy-back a connection onto the stock tach wire. Read my first post above for info on which wire that is.
If the vehicle does NOT have a factory tach the connection point is still there on the plug, but there's usually just a short pigtail of wire taped up on the connector, not attached to anything. That's the wire. Common in truck applications that don't have a factory tach.
Old 01-16-2009, 08:47 PM
No, I don't have a tach and I don't have a pigtail wire.
ChristinaMarie
09-11-2015 06:28 PM
Wylecoyote08
09-08-2015 08:26 AM
Ironhead38
09-07-2015 02:26 PM
TheExaminer
09-06-2015 11:40 PM
Ian Irvine
09-04-2015 08:08 AM
Quick Reply: Tach/Dwell reading question.
