Car runs for a while then shuts down??
Old 05-08-2009, 11:59 AM
Oldsmobileman's Avatar
Car: 1991 GTA
Transmission: Stock
Axle/Gears: Stock
1991 Gta 350 tpi. Car runs great, then shuts off. Replaced coil, replaced, plugs, replaced fuel pump, pick up sock, fuel filter, changed oil, fresh gas, replaced all rubber fuel lines. Car just shuts off as soon as you give it gas. Kind of dumbfounded at this point. Please someone help. Thanks, Howard
Old 05-08-2009, 12:02 PM
Car: 1991 GTA
Transmission: Stock
Axle/Gears: Stock
Re: Car runs for a while then shuts down??
Also replaced pick up in distributor and ignition mudule in distributor. Didn't help. Car will idle fine for about 15 minutes when you first start it, once it gets warmed up it will only run for a couple of minutes.
Old 05-08-2009, 05:06 PM
Car: 1991 GTA
Transmission: Stock
Axle/Gears: Stock
Anyone, Bueller, anyone? Bueller?
Sorry...the line was necessary.
I'll take guesses, I'm out of ideas.
Old 11-12-2009, 06:00 AM
Car: 1991 GTA
Transmission: Stock
Axle/Gears: Stock
Well, 3 professional computer scans and 3 different mechanics, and 6 months later... the problem is solved. One computer told us it was spark plugs, it wasn't. Another computer told us it was a heat bung on the block telling the cpu the engine was too hot and shuts it down, it wasn't. Yet another scan told us it was fuel pump/pressure it wasn't. In the end I replaced all these parts, and the problem was a shot out fuel injector. So if anyone else has the symptoms or problems I wrote about above, don't trust the cpu of you will *** over $500.00 in parts when a brand new injector is only $50.00.
kyleb24
08-15-2015 08:24 AM
djmarch
08-09-2015 05:27 PM
Kaweh
08-09-2015 02:54 PM
Fronzizzle
08-09-2015 01:15 PM
Quick Reply: Car runs for a while then shuts down??
