Identify these heads for me!
1 Post
Car: 1982+1988 Z28 Camaros
Engine: 1982=350 carb 1988=383 Carb
Transmission: 1982=4 speed T-10 1988=6 speed T56
Axle/Gears: 1982=stock
I've been under the impression the cylinder heads I have ar AFR's, but today when I went out to verify which version they were I couldn't see any AFR branding on them nor did the numbers I did find give me any results in google searches. These are the only numbers I can give you, I'll get some pics later if that will help:
3275R
195V
922732
They are aluminum heads. Please help identify these!
3275R
195V
922732
Re: Identify these heads for me!
Better take that pic, next to impossible to determine with those numbers....
If they were AFRs they would have an A cast (and faced/machined) in between the exhaust ports, even the really old ones have that. The brownfields wouldn't have that.
1 Post
Great tip, yes they DO have an "A" cast inbetween exhaust ports. Ill get that pic up..
1 Post
That's what I thought, but I wanted to get the specific model. Here's the pictures
Yeah, they look like older AFRs to me. I have a set of their (now discontinued) 190cc heads on my 383- probably 6-7 years old at this point. Before the "Eliminator" series heads came out and before they started engraving the AFR logo on the end of the head.
1 Post
I did searches on their website for those numbers I pulled, but no results. Is there any way to find out?
92projectcamaro
01-18-2016 08:00 AM
New2Chevy
09-28-2015 12:35 AM
