454 best cam - Third Generation F-Body Message Boards
454 best cam
Thread Tools Search this Thread
Old 06-22-2009, 12:42 PM   #1
Car: 92 RS
Engine: 2000 454 Carb
454 best cam
I have a 2000 454 that i am building for my 92 camaro. I am looking for advise on a cam that when my car idling it sounds like it has guts. Will gladly appreciate all help,
GSRMmi31 is offline vBGarage Page   Reply With Quote
Old 06-22-2009, 10:39 PM   #2
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: 454 best cam
Specs on the motor? CR, heads, etc.. if you actually build it to have 'guts' the sound will come with it.
Air_Adam is offline vBGarage Page   Reply With Quote
Old 06-22-2009, 11:52 PM   #3
ericjon262's Avatar
Car: 85 2M6 Fiero '86 K20 'Burban '70GMC
Engine: LX9, 350, LS9
Transmission: F23, TH400, TH350
Axle/Gears: ???, 4.10 14 bolt, 12 bolt
Re: 454 best cam
Quote:
don't build something that sounds fast, build something that IS fast!
ericjon262 is offline vBGarage Page   Reply With Quote
Old 06-23-2009, 08:12 AM   #4
Car: 92 RS
Re: 454 best cam
It is basically a gen VI 454 stock. I am working on getting manifold, carburator, water pump, oil pump, and distributor is on its way. I will also have to order the March serpentine pulley kit. Its progressing one step at a time. Any advise will help since this is my first time building a engine and i definitely want the car to be fast i need to run over my brother's 89 5.0 HO.
Old 06-23-2009, 09:59 PM   #5
Air_Adam's Avatar
Re: 454 best cam
Stock they were around 8.5-9:1 CR, so keeping the cam somwhere between 220-230* @.050 would be a good idea. Will keep driveability fairly good, and will sound nice too. Not raunchy, but it will have a bit of a 'cammy' sound to it.
Old 06-24-2009, 08:16 AM   #6
Car: 92 RS
Re: 454 best cam
What about something over 270 wold that be too rough for driveability since its a stock engine.
Old 06-24-2009, 10:53 AM   #7
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Re: 454 best cam
You're talking about advertised duration, Adam is talking about .050" duration. Different things. Cams with 270ish duration will most likely have in the range of 220-230 @ .050" duration.
Stekman is offline vBGarage Page   Reply With Quote
Old 06-24-2009, 11:03 AM   #8
Car: 92 RS
Re: 454 best cam
Thanks, I wish I knew more about engines. Maybe then I would make since with my replies.
Old 06-24-2009, 11:10 AM   #9
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
Re: 454 best cam
im running a 244/256 duration cam in my 454 block its bore and stroked to 489 and i have procomp 320cc aluminum heads and a weiand 871 roots blower on top. it has a lumpy sound to it but i have the rest of the motor for it.
roughskinjrz is offline vBGarage Page   Reply With Quote
Old 06-24-2009, 11:35 AM   #10
Car: 92 RS
Re: 454 best cam
Sounds like a ton of money spent. Can you post a pic, id like to see it if you dont mind.
Old 06-24-2009, 01:03 PM   #11
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: 454 best cam
Sound means nothing compared to performance. My 454SS pickup has a deep rumble but all I have is a mild Crane Compucam in it. The exhaust goes through dual Hooker Aerochamber mufflers to give the deep rumble.
My race car is full performance. Cam is .748/.748 with 286/298 @ .050 and 112 LSA. It idles smoothly at 1000 rpm. I do run Magnaflow race mufflers though because with open exhaust, I would need to use ear plugs just to fire the car up.
AlkyIROC is offline vBGarage Page   Reply With Quote
Old 08-08-2009, 11:09 AM   #12
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
Re: 454 best cam
here is a pic of it
Old 08-08-2009, 03:02 PM   #13
Re: 454 best cam
Thats a nice catch can in the lower right of that pic Clint..... I had one just like it.
You ever gonna send me the one you owe me?
Oh and for anyone who is wondering what I'm talking about..... Roughskinjrz here scammed me out of a $20 coolant overflow bottle in a trade for my catch can. He clearly has my old catch can in the above pic, but months later...I still have no overflow bottle. Here's a link over on the Maliburacing forums for all interested in reading. http://www.maliburacing.com/forum/vi...p?f=13&t=85269
And Clint...... I will be bothering you untill i get what you owe me.
Jim
Evil80 is offline vBGarage Page   Reply With Quote
Old 08-10-2009, 12:54 PM   #14
Car: 92 RS
Re: 454 best cam
Did you cut out the fenders for header clearance?
Thread Thread Starter Forum Replies Last Post
Cam Question Jorlain Tech / General Engine 6 10-08-2015 02:57 AM
Compiling twin turbo 5.3 LS setup customblackbird Power Adders 71 10-01-2015 05:30 PM
Spring locators for vortec head? sandman92084 Tech / General Engine 13 09-12-2015 11:27 PM
95 LT1 383 GM hotcam FPR required? Strick1 LTX and LSX 2 09-04-2015 08:11 AM
need help want to add some more hp z28guy134 Engine Swap 1 09-02-2015 12:50 AM
Go Back   Third Generation F-Body Message Boards >
Tags
454, 85, big, biggest, block, cam, camshaft, ci, cr, engine, gen, good, sound, stock, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
All content copyright 1997 - 2014 ThirdGen.org. All rights reserved. No part of this website may be reproduced without the expressed, documented, and written consent of ThirdGen.org's Administrators.
