smokin problem
Old 08-09-2009, 06:31 PM
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
smokin problem
i have an 84 camaro, 350 carbed motor. everytime i start it up whether itd be a cold start or warm start it smokes a little bit. its a blueish color. itll smoke when i romp on it and if im in park and reeve it up. will valve seals make it do that? any ideas?
Old 08-09-2009, 07:41 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: smokin problem
Typical valve seals. Nothing major to worry about - just keep an eye on your oil (as you should be anyway).
Old 08-09-2009, 08:02 PM
Engine: 355
Re: smokin problem
ya i figured it was that, how easy is it tp replace them on heads off a car?
Old 08-10-2009, 11:21 AM
Car: 1992 RS
Engine: Carbed 350
Re: smokin problem
easier to replace with heads off, but can be done with heads in the car - there are several threads on here on how with threads still in the car - search something like "valve seal replacement" and see what you find.
88rscamar0
09-23-2015 09:08 PM
pjsparts
09-17-2015 01:28 PM
Ranbo108
09-09-2015 12:20 PM
383cam
09-09-2015 06:01 AM
andy74
09-03-2015 08:41 AM
Quick Reply: smokin problem
